587,517 active members*
2,943 visitors online*
IndustryArena Forum > Material Technology > Composites, Exotic Metals etc > Deep indented mark at start point of carbon fiber
Results 1 to 7 of 7
    Aug 2017
    2
    I did my prototype before sending my dwg file to a shop to cut a 5mm thick carbon fiber sheet for me.
    The part suppose to be symmetry and smooth like the bottom part(green arrow), but the shop made a deep indented, drill mark(red arrow), which is 1 mm deep into my part.
    The shop claim it to be the start point point the drill and it is unavoidable. ( I don't have such problem using my chinese cnc)
    Anybody know what caused the indented mark? And what can I tell the shop to fix the issue?
    Thank you.
    http://www.cnczone.com/forums/attach...d=370938&stc=1http://www.cnczone.com/forums/attach...d=370942&stc=1
    Aug 2017
    21
    Re: Deep indented mark at start point of carbon fiber
    i would look at the fixturing
    whatever they are doing they are consistent !
    why do i think they are waterjet cutting this ??? if they are water jet cutting they are "piercing" to the inside/outside which will leave the "notch"
    if the profile is critical, start the cut at a non-critical point or just cut outside towards part .
    how are they cutting this
    Aug 2017
    2
    They are using double sided tape for to hold the carbon fiber.
    I think they are using cnc milling, not by waterjet, since there is milling marks on the side.
    http://www.cnczone.com/forums/attach...d=370948&stc=1
    Apr 2009
    5516
    Ramp in not plunge in
    Jan 2005
    15362
    Quote Originally Posted by storage View Post
    Thank you.
    Looks like a screw up who ever did the job
    Mactec54
    Dec 2013
    5716
    The tool path needs a leadin to eliminate that. Maybe it should be done in two passes, rough then a finish pass with leadout.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2008
    683
    They didn't use a lead in or an overlap.
  1. Lasercut 5.3 start point and end point not matched and curve line not smooth?
    By shizyo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-21-2019, 11:26 PM
  2. 1mm bit for Carbon Fiber?
    By thePrestige in forum Composites, Exotic Metals etc
    Last Post: 01-30-2014, 01:13 AM
  3. Tools for machining solid carbon (not carbon fiber)-more posted
    By camcutter in forum Composites, Exotic Metals etc
    Last Post: 04-28-2007, 12:23 AM
  4. Carbon Fiber
    By DrasticSports in forum Employment Opportunity
    Last Post: 03-30-2006, 12:19 AM
  5. Carbon fiber
    By CNC Pro in forum Community Club House
    Last Post: 03-13-2004, 11:32 AM
