I'm a bit unclear on how to get this z-axis shaft out. Even if I were to remove the C-clip (#822), I can't see how the shaft would some out.
Some please educate me.
Attachment 458176
Attachment 458178
Printable View
Attachment 458176
Attachment 458178
It looks like you remove the feed rod, remove the coupler, remove the cover with the three screws on the right end. Do similar on the left end. Then it appears that there's a set screw in the middle boss in the bear box. Pull that out and the shaft should be able to move to the left or right.
Chris,
Looks like you responded last night, so not sure why I just got an email notice for your response.
I did get it figured out today. The screw was the part I was missing.
Thanks!
That's great. I'm glad you got it figured out.
