EZpath lathe Alarm Power/off manual
Our Bridgeport EZ Path lathe is giving an alarm. Alarm power/Off manual... hit any key. When I hit any key it switches to Alarm Emergency Stop Activated.... Hit any key. When I hit any key it does not clear. Not sure where to start any help would be great.
Thank you, Ed
Re: EZpath lathe Alarm Power/off manual
All set. Not sure what I did to fix it tho. I reset with red button on front . had same alarm. then I pushed and pulled both emergency stops one at a time. Then moved the spindle control handle forward and back. Pressed 0 and it went to the usual start up screen. I don't know maybe a stuck emergency stop button. I had cycled thru all the above several times before with no success,maybe not in the same order. Well love this site we'll see if she stays running. Post was not up long before fix so no replies but I'm sure there would have been.
Great site ,Great community thank you,
Ed
