587,515 active members*
2,836 visitors online*
Results 1 to 3 of 3
    Dec 2014
    2
    X axis design help
    I am currently designing a 5' x 10' R&P machine.
    My question will no doubt get arguments from both sides of the fence.
    Which is a better design?
    20-25mm round supported rails with an R&P drive system or 1/4" 1018 cold rolled plate with linear carriages with an R&P drive system?
    I am looking for precision as well as smoothness in action. Cost is not a problem at this point in design.
    Thanx in advance!
    35538
    Re: X axis design help
    Imo, neither. Each has their own issues.
    If cost is not an issue, go with profile rail linear guides.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2020
    8
    About the axis material. What is the best? P20 steel, H13 Steel or other?
  1. need Z axis design advice- dahlgren engraver -> full Z axis- how much Z travel?
    By lkasdorf in forum Uncategorised WoodWorking Machines
    Last Post: 05-11-2013, 02:50 PM
  2. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  3. Now....the Z-Axis Design ?
    By cncadmin in forum DIY CNC Router Table Machines
    Last Post: 12-07-2006, 08:00 PM
  4. Now....the Z-Axis Design ?
    By RakmUp in forum DIY CNC Router Table Machines
    Last Post: 11-29-2006, 10:24 PM
  5. 5-th axis design
    By georgebarr in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2004, 10:06 PM
