585,676 active members*
4,255 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Z axis waviness artifact in contour milling
Results 1 to 4 of 4
    Jun 2014
    0
    Anyone doing fine contour milling with their Haas? We have a 2008 OM-2A that consistently produces a wavy surface where it should be flat or smoothly undulating. It appears that every ~0.85mm of Z travel, the Z axis is low by a few micron, so that no matter how we mill a part, we see horizontal stripes in the play of light on the surface. I put a micron gauge in the machine and found that the Z axis can take a while (seconds) to settle at certain heights -- again, roughly 0.85mm apart. I suspect this is a control issue and not a mechanical one, because there's no simple relationship to the Z screw pitch. I wonder if the problem is unique to our machine, or if others have seen the same motion/positioning artifact and found a workaround.
    Nov 2006
    490
    Re: Z axis waviness artifact in contour milling
    I know the "settling" you mentioned. You can often hear it on the larger machines, and you can watch the position correction move around when in diagnostic mode.
    But I can't say I've had much issue with it when actually engaged in a cut. I have more trouble trying to get rid of the polygonal smoothing leftover by the CAM software's filter.
    I should mention that I've never used an office mill, though...
    May 2012
    67
    Microns,
    What are your Z backlash (parameter 41) and Z friction comp (parameter 140) parameters set to? I would run a ballbar test, make sure if you do that the tech runs the Z axis! Most take the easy route and just run an XY test.
    Thank you,
    Phil
    Sep 2006
    48
    As PMT mentioned, you should check for backlash in your Z axis ballscrew. Also check for tool deflection. What spindle RPM are you running?
  1. Pocket Milling Problem - selecting contour
    By Outdoormoto in forum Uncategorised CAM Discussion
    Last Post: 08-18-2013, 05:46 AM
  2. 5 axis contour
    By juxtoposed in forum Mastercam
    Last Post: 11-21-2012, 07:19 PM
  3. Compensation in Mill-Turn Profile contour milling
    By maparkopo in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-26-2012, 03:11 PM
  4. Milling 2D contour and clean up stock around it
    By scot1911 in forum BobCad-Cam
    Last Post: 10-03-2010, 09:18 PM
  5. Weird artifact in SW DXF file.
    By polymath in forum Solidworks
    Last Post: 07-01-2008, 07:22 PM
