Originally Posted by
Noyrt
Thank you for the reply, it did this a couple of times then was it went away, at least for now? Not sure if the problem will come back or not? Glad to know it is at least not causing any damage. I did go through some of the basic calibrations in the book for SIG and BALANCE related to the servos. (adjusted the little POT on the boards to try to balance the voltage). It was not too far off, but figured it couldn't hurt to check it. I never found anything wrong, however?
Thanks, for the reply.
Tryon
