Hey I appreciate any help you guys could give me. I have a cnc router I bought as a kit and put together. I'm using Mach3 software. When I zero the Z axis on the top of the part surface, when I run the program, the Z axis moves up farther than it should. So it's only cutting air. If I re-zero it again, it usually does okay. Any thoughts on what could be wrong? Thanks in advance!
