Hello,
I have bought the 3020Z-D52, the new version with the black box, ballscrews and the couplings are spiral with set screw.
The machine is losing some steps and I don't know why happened this.
I replace the cables with shielded, I tried with different speeds but the problem hasn't solved.
I made an engrave, cutting in wood and the final result isn't good.
The letters are not straight, has inclination of a few degrees to the bottom.
The letters on the CAD are straight.
I have the same problem and with PCB engraving, cutting, drilling.
I'm thinking to buy the Gecko G540 but I don't know if the problem is from stepper driver.
Is any solution to do?
Thank you in advance
Nikos
