585,581 active members*
3,802 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Which solution for SCM 5 Axis CNC?
Results 1 to 5 of 5
    Jan 2012
    19
    Hi all,
    This is a recurring thread, but I hope the specifics of my question warrant starting a new one.
    I run a company in Madrid, Spain, in which I use a SCM Pratix Z5, 5 axis CNC machine, with a 3x1,5m worktable.
    I make all sorts of furniture and pieces, there is little repetition, so I need something flexible, that allows me to do 5 axis interpolation easily. Since this is a business and luckily growing, I am prepared to spend money on the software, I'm not looking for a budget/pirated solution, but for a top of the line software, that comes with training and support.
    In Europe most people seem to take Alphacam as the only option, but thanks to CNCzone, I do wonder if that's the best option for me. I would like a software that allows me to do whatever I can think of, and ideally with a cabinet making solution, whereby I tell it sizes of a cabinet, joinery I wish to use, and it will generate a cutting list and all programs without having to tell it where I can this drill, that dowel or whatever.
    Please let me know if you require any more information to respond. So far I have asked Alphacam and Mastercam for quotes, but welcome any advice. I don't want to spend 12K on a software to find out a few months down the line that it wasn't the ideal option!
    Thanks,
    Marcos
    35538
    Re: Which solution for SCM 5 Axis CNC?
    I think that SCM has a partnership with AlphaCAM. Our Morbidelli (from SCM) came with AlphaCAM as well.
    As far as I know, AlphaCAM and MasterCAM are probably the biggest 5 axis woodworking specific packages out there.
    I'm not familiar with any 5 axis software for cabinetmaking. There are plenty that will do what you want for 3 axis, but I doubt you'll find an automated 5 axis solution for your cabinet parts.
    You probably need to research all the cabinet programs available, and see if any support 5 axis? Cabinet vision, or Top Solid are two main ones.
    Even if you find a cabinet package to support 5 axis, you'll probably still need a separate 5 axis CAM package for non cabinet parts.
    You might also consider Rhino and RhinoCAM or MadCAM.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2012
    19
    Thanks Gerry,
    I also think there is some sort of partnership. When I was visiting the SCM factory in Italy, whenever I asked how to do something complex, the operator's response was "Alphacam". I am on the right path then with alpacam and mastercam. I will also look into Rhino and MadCAM. Note taken on the fact that I might want to consider the 5 axis software and the cabinet solution as two separate things, that makes quite a lot of sense...
    I believe the distributor in Spain for Mastercam also carry Topsolid and various other solutions, so hopefully they'll be able to advise.
    Cheers, Marcos
    Oct 2013
    109
    SCM 5 axis machines are very commonly teamed up with Alphacam. Also a good choice for the woodworking environment.
    Jan 2012
    19
    I just had a demo for Topsolid and was very impressed. It seems to be a solution like Alphacam, but adding a furniture design feature kind of like sketch up. The good thing is they are both integrated, so you get alphacam's functionalities, ADDING furniture design with a ton of options and cool things. I am very interested, I now am waiting for a quote, though I fear it is going to be more expensive than the already pricey alphacam... Any experience with topsolid anyone?
  1. The next go-to 3-axis drive solution for DIY CNCs?????
    By louieatienza in forum DIY CNC Router Table Machines
    Last Post: 10-03-2013, 04:32 AM
  2. Need serial port 4th axis stepper solution
    By zaebis in forum Stepper Motors / Drives
    Last Post: 09-24-2010, 12:27 PM
  3. Recommend Solution For Single Axis
    By Mcyoda in forum CNC Machine Related Electronics
    Last Post: 05-07-2010, 02:46 PM
  4. Simple Z axis solution for BP J Head retro
    By DennisCNC in forum Bridgeport / Hardinge Mills
    Last Post: 07-24-2006, 04:41 AM
