585,744 active members*
4,991 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > which cam program to use full 5 axis machining no indexed
Results 1 to 12 of 12
    Sep 2014
    7
    hi friends i am importing a cnc mini machine from china 5 axis column type, then i need a cam program that allow to made a toolpath or gcode to full 5 axis machining like to made a impeller for example, i am in project to made cylinder heads for motorcycle any help would be very grateful thnaks
    Jan 2005
    15362
    Re: which cam program to use full 5 axis machining no indexed
    encex
    This will depend on how much you want to spend, Gibbs Cam is one to look at
    Mactec54
    Sep 2014
    7
    encex
    how much it is gibbs cam? i want to spend the less posible but i need continuous 5 axis machining 4 and 5 axis!
    Jan 2005
    15362
    encex
    You will have to do a search for the different 5 axes simultaneous, nothing is cheap when it come's to 5 axes simultaneous, there are a lot that do 5 axes cam software, but not all are simultaneous
    Some more to look at Onecnc, Hypermill, PowerMill, BobCad Cam, SprutCam, there are many that can do 5 axes simultaneous, just make sure it will do what you want, for prices you will have to contact the company's
    Mactec54
    Sep 2014
    7
    encex
    ok my friend one more questions is the sprutcam demo trial version fully workable to made gcodes?
    Jan 2005
    15362
    Quote Originally Posted by encex View Post
    It used to be, but have not tried SprutCam for some time, I'm sure if you contact them would be best
    Mactec54
    Sep 2014
    7
    ok thanks!
    Sep 2014
    2
    Any one can help me about my machine DMU 50 model i have a problem regarding the coolant thru spindle not function even i command M28 or M7
    Mar 2013
    1
    Maybe You should also try DeskProto they have a multi axis version with a trial of 30 days.
    Jul 2011
    6
    Hello,
    I know few cam software i think that the best one for 5Axis is Hypermill,
    Jul 2011
    6
    Are you sure that this is the right Code?
    Jul 2011
    6
    Gibbs Cam is a good software just for cam, the cad is really bad.
  1. Replies: 12
    Last Post: 09-06-2013, 01:02 PM
  2. My first full program
    By 3rdGen in forum G-Code Programing
    Last Post: 06-10-2013, 11:20 AM
  3. Replies: 10
    Last Post: 06-04-2012, 12:35 AM
  4. Madcam - 4 axis indexed ring machining
    By etzz in forum MadCAM
    Last Post: 08-28-2008, 06:54 PM
  5. 5 Axis indexed vs 5 Axis continuous
    By jwolin in forum Uncategorised CAM Discussion
    Last Post: 03-24-2007, 08:21 AM
