585,768 active members*
4,085 visitors online*
Results 1 to 15 of 15
    6855
    What is G-code?
    G-Code is the common name for the programming language of CNC Machines. Somewhat of a generic, catch-all type of term for CNC programming language. Very few machines adhere to this standard today. There are as many varations as there are manufacturers.
    Jan 2011
    24
    Re: What is G-code?
    Are G codes and M codes same for all machines..
    Here to learn, share and stay.
    Dec 2003
    24220
    Re: What is G-code?
    No, they depend on whether its a Mill, Lathe,PLasma, Punch etc, they all have their own method of G code.
    The M code is fairly standard, but depends on the whim of the MTB, not the control manuf, as it is in G code.
    Al.
    Albert E.
    Jan 2011
    24
    What is G-code?
    MTB?? Machine tool builder?
    Jan 2011
    24
    Re: What is G-code?
    Jan 2011
    24
    Re: What is G-code?
    As far as I know.. Fanuc and Siemens are the two big players with few MTBs coming with their own controls. Which among them is better in what aspects.. And does it make a real difference in the output quality
    Dec 2003
    24220
    Re: What is G-code?
    Quote Originally Posted by acejunker View Post
    Don't forget Mazak (Mitsubishi) of which Mitsubishi also manufacture machine tools, which is rare.
    Most of the major Control manuf have their own unique feature of some kind, I find there is not a lot between them, another thing to consider is support and technical assistance.
    Al.
    Albert E.
    35538
    Re: What is G-code?
    Most big industrial woodworking machines use their own proprietary controls, with many proprietary g and m codes.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2003
    24220
    Re: What is G-code?
    I see no purpose in deviating from the normal G codes that apply for a certain type of machine, this was the original concept of the International ISO G-code standard anything else leads to confusion between machines of the same type?
    Al.
    Albert E.
    Jan 2011
    24
    Re: What is G-code?
    When and where are G codes and M codes used in a program(asking for overview). To generate a program is it necessary to memorise these codes??
    Dec 2003
    24220
    Re: What is G-code?
    Not sure of the actual question, but if you want to learn about G M code programming, get the CNC programming book by Peter Smid.
    You need the control manuf programming manual and the MTB's M code designation for a particular machine.
    Al.
    Albert E.
    Jan 2011
    24
    Re: What is G-code?
    Precisely what I needed. Thanks
    Jan 2015
    3
    Re: What is G-code?
    what is G code how it increases its vale like BCD
    Dec 2003
    24220
    Re: What is G-code?
    Quote Originally Posted by hashim2000 View Post
    G-Code is not a processor programming language per-se, but more a form of CNC part program format.
    Al.
    Albert E.
    Re: What is G-code?
    G-code (also RS-274), which has many variants, is the common name for the most widely used numerical control (NC) programming language. It is used mainly in computer-aided manufacturing for controlling automated machine tools. G-code is sometimes called G programming language. That's the general idea from Wikipedia, hope can be helpful~
    ISweek(http://www.isweek.com/)- Industry sourcing & Wholesale industrial products
  1. Replies: 51
    Last Post: 09-16-2020, 01:28 AM
  2. G-Code Ripper - Scale, Rotate and Split G-code
    By scorch in forum OpenSource Software
    Last Post: 08-26-2020, 03:28 PM
  3. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  4. Converting Fanuc G code to Seimens 840D G code
    By Jasbinder in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 02-20-2011, 05:02 PM
  5. Replies: 8
    Last Post: 12-15-2010, 09:32 PM
