584,865 active members*
4,881 visitors online*
Results 1 to 4 of 4
    Apr 2011
    720
    Weird Zeroing Problem
    Hi All,
    Having a strange problem that has me pulling hair, and I don't have enough to spare.
    I have a spotting drill in my mach 3 tool table that I have used many times before. Today after zeroing my part with a probe, I started using that drill, but noticed it was going too low before the programmed z movement.
    I double checked part zero, as well as the tool length against what was in the tool table, and everything was spot on.
    I must have remeasured the tool length a dozen times, but every time I checked the z zero for that tool in the spindle it was low by roughly 40 thou. Went into the " what the heck is going on mode" then I remembered that tool was in the tool table twice with two different numbers, because of old projects. Both entries in the table had the exact same length, but when I selected the other tool number and checked the z zero against the part, it was perfect???
    Is this maybe a corruption of the tool table data, or something else unusual?
    If anyone has had similar experiences or has any ideas, I'd love to hear them.
    Terry
    Nov 2010
    291
    Re: Weird Zeroing Problem
    When you select the tool and press enter, is the z offset showing the same with each tool? Maybe it is the same in the tool table but somehow put some extra offset in somehow.
    Apr 2011
    720
    Yes when I put each tool number into the MDI, they both read the same Z? I can't see anything in the offsets anywhere to account for it. I guess I will just delete the data for that tool number from the table, and chalk it up to "stuff happens". LOL
    Thanks for the reply
    Terry
    Nov 2010
    291
    Weird. I haven't used mine enough to know a whole lot about these quirks. I would do the same and like you said, chalk it up.
  1. Replies: 1
    Last Post: 08-17-2013, 07:02 AM
  2. Problem zeroing Z on a Mitek with Fagor control
    By Todd H in forum Uncategorised MetalWorking Machines
    Last Post: 11-06-2012, 05:32 PM
  3. Weird problem with a 6MB controller.
    By ckirchen in forum Fanuc
    Last Post: 01-13-2008, 07:38 PM
  4. i've got a weird problem
    By fast89 in forum CNC Machine Related Electronics
    Last Post: 12-19-2007, 09:31 AM
  5. Having weird problem
    By rustamd in forum Uncategorised CAM Discussion
    Last Post: 11-24-2007, 12:58 AM
