I recently purchased this machine and replaced z axis motor complete with wire harness from Milltronics. The old unit was bad. Since I have replaced unit I have only run machine a few hours.
I power up machine and reset drives, home machine everything ok.
I can run machine with no faults.
If I let machine set idle for some time with drives enabled when I start moving machine the z axis starts oscillating up & down about 1" - 1-1/2" then faults out LS/ECB light comes on.
I blocked head & removed belt. I e-stopped tried turning motor shaft (Can't turn brake is working). Reset drives and tried turning motor shaft (With a little turning motion the motor starts oscillating then 449 fault).
If I power down machine and power back on the same thing happens.
If I wait for sometime (2 -3 hours) and power back on everything seems ok until it sets idle for 2 - 3 hours with drives enabled.
This has got me puzzled.
Any ideas as where to start?
