585,779 active members*
3,953 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V27 Thread Milling Help - No Z code posting
Results 1 to 8 of 8
    Dec 2014
    9
    I'm doing a simple thread milling operation and can't seem to get BobCam to post any Z values in the G02 posting routines.
    This is a simple 1.2" deep 1/2-13 thread operation. I don't get it. There should be a Z offset for each of the arc operations. What am I doing wrong.
    It even shows the z helical interpolation in the graphic on the screen and in the on screen simulation but the posted G Code has no Z offsets in it so the threadmill goes toward the top of the hole and just spins around there! Pulling hair out! Help.
    BobCam settings.
    Feature: Mill Thread
    Diameter: .50
    Top of Feature: 1.2
    Total Depth: 1.2
    Posting
    Arc Moves
    Thread Mill
    Diameter: 0.3720
    Protrusion Length: 1.5
    Patterns
    Top Down
    Inside
    Parameters
    Right Hand
    Thread Diameter: 0.5000
    Thread Height: 0.0666
    Thread Pitch: 0.0769
    Threads Per Revolution: 1
    Threads Start Angle: 0
    Depth: 1.2000
    Leads
    Lead-In/Lead-Out
    Circular
    Radius: 0.0500
    Resulting GCode
    (Machine Setup - 1 Mill Thread)
    (FEATURE MILL HOLE - 0.5000)
    N18898 T17
    N18899 S5140 M03
    N18900 G90 G54 X-2.5938 Y-2.625
    N18901 G43 H17 D17 Z2.2 M08
    N18902 G00 Z1.4
    N18903 Z1.3
    N18904 G01 Z1.2 F59.11
    N18905 X-2.5798 Y-2.575
    N18906 G17 G02 X-2.5298 Y-2.625 I0. J-0.05
    N18907 X-2.6578 Y-2.625 I-0.064 J0.
    N18908 X-2.5298 Y-2.625 I0.064 J0.
    N18909 X-2.6578 Y-2.625 I-0.064 J0.
    N18910 X-2.5298 Y-2.625 I0.064 J0.
    N18911 X-2.6578 Y-2.625 I-0.064 J0.
    N18912 X-2.5298 Y-2.625 I0.064 J0.
    N18913 X-2.6578 Y-2.625 I-0.064 J0.
    N18914 X-2.5298 Y-2.625 I0.064 J0.
    N18915 X-2.6578 Y-2.625 I-0.064 J0.
    N18916 X-2.5298 Y-2.625 I0.064 J0.
    N18917 X-2.6578 Y-2.625 I-0.064 J0.
    N18918 X-2.5298 Y-2.625 I0.064 J0.
    N18919 X-2.6578 Y-2.625 I-0.064 J0.
    N18920 X-2.5298 Y-2.625 I0.064 J0.
    N18921 X-2.6578 Y-2.625 I-0.064 J0.
    N18922 X-2.5298 Y-2.625 I0.064 J0.
    N18923 X-2.6578 Y-2.625 I-0.064 J0.
    N18924 X-2.5298 Y-2.625 I0.064 J0.
    N18925 X-2.6578 Y-2.625 I-0.064 J0.
    N18926 X-2.5298 Y-2.625 I0.064 J0.
    N18927 X-2.6578 Y-2.625 I-0.064 J0.
    N18928 X-2.5298 Y-2.625 I0.064 J0.
    N18929 X-2.6578 Y-2.625 I-0.064 J0.
    N18930 X-2.5298 Y-2.625 I0.064 J0.
    N18931 X-2.6578 Y-2.625 I-0.064 J0.
    N18932 X-2.5298 Y-2.625 I0.064 J0.
    N18933 X-2.6578 Y-2.625 I-0.064 J0.
    N18934 X-2.5298 Y-2.625 I0.064 J0.
    N18935 X-2.6578 Y-2.625 I-0.064 J0.
    N18936 X-2.5298 Y-2.625 I0.064 J0.
    N18937 X-2.6444 Y-2.5859 I-0.064 J0.
    N18938 X-2.5743 Y-2.5769 I0.0396 J-0.0306
    N18939 G01 X-2.5938 Y-2.625
    N18940 G00 Z1.4
    N20274 Z2.2
    N20275 M09
    N20276 M05
    N20277 G91 G28 Z0.
    N20278 G91 G28 X0. Y0.
    N20279 M02
    Dec 2013
    290
    Re: V27 Thread Milling Help - No Z code posting
    Under the posting tab, change countour ramping output to line moves, default is arc moves.
    Dec 2014
    9
    Yuck! That's not helical interpolation. That's doing it by hand. That's what you do when you have a mill that doesn't support G02 or G03. Is there a bug that keeps bobcad from putting the appropriate Z moves when you use G02 and G03?
    Dec 2014
    9
    I think I figured it out guys. There seems to be a bug in the post processor downloaded from Bob Cad's website. I replaced this line...
    64. Arc move XY.
    n,g_arc_plane,g_arc_move,x_f,y_f,arc_center,feed_r ate
    with this line...
    64. Arc move XY.
    n,g_arc_plane,g_arc_move,x_f,y_f,z_f,arc_center,fe ed_rate
    and voila the Z interpolations are there! Hope this helps some other people.
    Jun 2008
    1838
    You are correct, that is the reason
    Here is the code I get using the standard BCx3x.MillPst, seems spot on to me
    (FIRST MACHINE SETUP - Machine Setup - 1)
    N01 G00 X0. Y0.
    N02 Z5.
    N03 Z1.
    N04 G01 Z0.375 F53.821
    N05 X5. Y5.
    N06 G17 G02 X10. Y0. Z0. I0. J-5.
    N07 X-10. Y0. Z-0.75 I-10. J0.
    N08 X10. Y0. Z-1.5 I10. J0.
    N09 X-10. Y0. Z-2.25 I-10. J0.
    N10 X10. Y0. Z-3. I10. J0.
    N11 X-10. Y0. Z-3.75 I-10. J0.
    N12 X10. Y0. Z-4.5 I10. J0.
    N13 X-10. Y0. Z-5.25 I-10. J0.
    N14 X10. Y0. Z-6. I10. J0.
    N15 X-10. Y0. Z-6.75 I-10. J0.
    N16 X10. Y0. Z-7.5 I10. J0.
    N17 X-10. Y0. Z-8.25 I-10. J0.
    N18 X10. Y0. Z-9. I10. J0.
    N31 M05
    N32 G91 G28 Z0.
    N33 G91 G28 Y0.
    N34 G90
    N35 T1 M06
    (END OF FILE)
    N36 M30
    (END OF PROGRAM)
    Regards
    Rob
    :rainfro: :rainfro::rainfro:
    Dec 2014
    9
    Dang Rob, those are some big ass threads.
    Jun 2008
    1838
    Quote Originally Posted by hawkeyeammo View Post
    Errr, not really, it`s a 30mm dia hole with an internal thread of 1.5mm pitch 10mm dia thread mill, pretty normal sort of job for the boys on the shop floor to attack
    Not much to "screw" up there if you pardon the pun
    We all got "metricised" back in `72 and yes it hurt
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Apr 2009
    3376
    Quote Originally Posted by The Engine Guy View Post
    Regards
    Rob
    Metric Suks
