585,741 active members*
5,189 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > v26 Advanced rough issue
Results 1 to 7 of 7
    Sep 2009
    105
    I've noticed that when using advanced rough or advanced pocket the program will leave a small nick on the "front edge" or the edge where the tool enters the part. Some example pictures are attached. It doesn't seem to me to be something that you could address with a finish pass. Are you guys experiencing this? Any way of getting rid of it? My parts are pretty much all tooling that stays in house so it's not a huge problem but I'd like to know how to fix it.
    May 2013
    701
    Re: v26 Advanced rough issue
    It might be that intermediate step problem your seeing. I was running into that with V25 and is probably the same in V26. Does the gouge report show them.
    Just upgraded to V26 a couple of weeks ago so not sure if it has been fixed or not. I'm going to load a file that I was having trouble with and see if I need to get with Tech within the 45 day window. Thanks for the remind.
    RAF.
    Apr 2009
    3376
    Can you replicate it in a file you can share with us ?
    It looks like something I would do on the manual mill when I was first starting out,lol (turning the handles the wrong way)
    Aug 2012
    621
    Seems like I remember seeing a video where that was addressed by using <Surface> [Extend] to basically tell the software that the geometry that's being cut extends just far enough out that the cut takes place in air, rather than stock. Probably need to unstitch, extend, then restitch or boolean add it back together.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Sep 2009
    105
    I've had some trouble accessing the zone to post the resolution to this. It turned out to be a misunderstanding on my part. This part was an existing tool that I was modifying by putting in the pocket seen in the picture AND opening up the radius which is "damaged" by the nick. So basically it got erased by my second operation. Guess I got ahead of myself, but I'm almost positive I've seen similar issues on previous parts. Did I do the same thing in those other cases? I'm not sure anymore so I'll just have to wait and see if it happens again.
    Mar 2012
    1570
    Intermediate steps:
    You can run into a sorting issue when using intermediate steps. Change your processing from area to level and it should eliminate any issues of the intermediate cut, cutting out of order.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Apr 2008
    1577
    Quote Originally Posted by Ben S View Post
    I see. I think Luke knew what you were getting at.
    Attachment 245406
    At first I thought you were talking about the area in the circle, it looked like a gouge but it was hard to tell.
    You CAN eliminate that by extending a surface or putting a primitive solid like a cube (assuming you are using 3D Adv Rough) in the way of the cutter so it avoids the area. In 2D Pocket -> Adv. Rough it can sometimes be a little trickier but is usually as easy as extending your geometry just a bit past the cast/stock that you are working with.
    The 3D Adv. Rough always obeys the allowance value. It should never leave a mark like that unless there is material there to remove. That is why I tend to favor the 3D methods in general.
  1. V25 Advanced Rough Arcs
    By mtmmfg in forum BobCad-Cam
    Last Post: 03-18-2014, 03:43 PM
  2. V25 PRO Advanced Rough/Adaptive Rough
    By RAF. in forum BobCad-Cam
    Last Post: 10-09-2013, 03:51 PM
  3. advanced rough
    By bobcad guy in forum BobCad-Cam
    Last Post: 05-11-2013, 06:58 PM
  4. advanced rough strikes again
    Last Post: 05-07-2013, 03:54 PM
  5. Advanced rough
    By Koblenzer in forum BobCad-Cam
    Last Post: 09-30-2011, 09:41 PM
