585,974 active members*
4,338 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Ultimax 3 Detail zero point lost after reboot?!
Results 1 to 4 of 4
    Nov 2014
    21
    Hi!
    I'm seeng strange thing with the Ultimax 3 software. I want to use G-code prog that's made in CAM-system. I'm loading the program on HDD. After that, I'm setting the zero point of the stock, starting the program, but after some time I need to shut the machine down. When I restart it - all the points are lost. Everywhere are the standart numbers... That's strange for me, especially after the Fanuc and Fagor CNCs, that I've been using before.
    How do I store points in the Hurco? I don't want to write down the numbers on paper every day and put them back every day again! What do I do wrong?
    Nov 2008
    28
    Re: Ultimax 3 Detail zero point lost after reboot?!
    I am not sure this function was implemented in your software - from input screen go to import/export softkey and use Save NC State to file. It saves tools and part setup data. You need to do it only for NC mode. In conversational mode tools and part data is stored in every program *.hd3 file.
    Sorry for my English... :|
    Nov 2014
    21
    Yes, there is such option in my machine. So, do I need to make this operation every time I stop my machine? Isn't that strange? Or it's normal for Hurco?
    Nov 2008
    28
    It could be normal for this software version. I am not sure... As I remember you do not have to save NC State on software version 2.3X (you can of course). Reboot doesn't clear this data...
  1. Lost reference point
    By arturonaupa in forum Fanuc
    Last Post: 05-29-2013, 11:18 PM
  2. Re-Calibrate After Every Reboot?
    By RPCElectronics in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2012, 11:12 PM
  3. TW10 needs reboot...
    By maximusek in forum Uncategorised MetalWorking Machines
    Last Post: 12-16-2011, 04:03 PM
  4. Lost reference point
    By Finnur in forum Uncategorised MetalWorking Machines
    Last Post: 11-23-2009, 10:50 PM
  5. Reboot
    By hobby81 in forum Bridgeport / Hardinge Mills
    Last Post: 04-20-2007, 04:27 PM
