Turnkey: Pro Level CNC Router Parts 5 axis 4' X 8' with V-Con + Mach3 + High Powered Desktop
***We are willing to ship and motivated to sell - just didn't like the shipping options provided.***
After about 6 weeks in production, we have decided to dramatically alter our production process and as a result have no need for this unit. We spent about 200 hours assembling, tuning and calibrating the machine and it is turn key ready.
The sale includes:
Pro CNC machine
Control box and all electronics
A custom built and very powerful desktop computer
Mach3 with our tuned profiles
Pepperl + Fuchs Proximity Limit Switches
Extremely stiff and robust custom built stand
Cable Track Kit
Router Mount and Router
The Nema 34 motors can accommodate rapids of up to 1200 IPM with production speeds of 500 IPM.
We added a fifth axis controller but have not implemented any tooling with it. I have included below an abbreviated summary from CNC Router Parts on the machine.
The PRO4896 CNC provides a huge work area that supports working with large materials, like full 48" x 96" plywood or 49" x 97" Medium Density Fiberboard (MDF) sheets.
The PRO4896 features their V-Con linear motion system, PRO Rack and Pinion drives on the X and Y axes, and Ballscrew Z Axis, offering higher speeds, greater stiffness and spindle capacity than the standard CRP4896 machine.
It is designed to easily expand to a larger machine in the future simply by adding more framework, gear rack and V-Con components.
Specs:
Work Area:
X: 99.5"
Y: 51.5"
Z: 8" (expandable to 12")
Footprint: 62" (1575mm) x 112.2" (2850mm)
Nema 34 motors: Rapids up to 1200 IPM+, cutting feedrates 500 IPM+*
Repeatability to +/-0.001" or better, accuracy to +/-0.005" or better (verified through our applications)
The cold rolled steel rails use for the V-Control Rail and V-Bearing system have been case hardened to a Rockwell HRC 60+ rating through a heat-treating process. While this is not strictly necessary for normal machine operation, it helps to prevent superficial wear marks and can result in longer-lasting rails under heavy use conditions.
The machine and software have functioned excellently - they just don't match our application. We would consider delivery within 400 miles of Austin, Texas for a negotiated fee. We would also potentially consider a partial trade for tools we could use, i.e. top tier cabinet saw, Shelix or sanding planer, dust control infrastructure, etc.
List Date: 12/2/2014
For more info, click here to view the original listing: Turnkey: Pro Level CNC Router Parts 5 axis 4' X 8' with V-Con + Mach3 + High Powered Desktop
On Sale For: $14,000.00 + $1,000.00 Shipping
Mobile friendly version: Turnkey: Pro Level CNC Router Parts 5 axis 4' X 8' with V-Con + Mach3 + High Powered Desktop
