I've always had a sticky tool holder issue with our RH33, usually after at starts to pop when changing tools a quick rub with scotch-brite pads will fix it for a while. Recently it has become worse and i can no longer use the tool changer with fear off breaking more of the plastic holders. I sometimes now have to use a hit with a deadblow while someone presses the tool out button to get the holder out. I have confirmed that oil is getting into the air-system. One small drop for every 3-4 tool changes. Pull studs look to be just fine, do they need a dab of grease or something every now and then? I polished the spindle and holder surfaces and even tried a bit of light oil on them. I don't leave them in overnight. I can put a tool in and out no problem most of the time, until the tool is ran. Even light cuts for a minute will create the sticking issue. Any thoughts? Machine is only a couple years old, with not very many hours on it
