Need help deciding which bit to use for your next routing project? Our experts are waiting to help! Here at CNC Router Store, we provide expert advice on which tools you need to get the results you want.
Happy Friday everyone! We’ve been in a decorating and designing mood lately as the summer months are winding down. This week, we had a customer looking to engrave designs into all kinds of material ranging from wood to plastic to aluminum. The customer wanted a range of sizes in order to make different designs without needing to make numerous passes with a single bit.
We recommended the Onsrud 37-00 series single flute solid carbide engraving tools. These bits come in a wide range of tip sizes in 30º and 60º angles to accommodate many engraving styles. For those who prefer using metric units, there is also Onsrud series 37-20.
Don’t forget to check out our new feed rate calculator on cncrouterstore.ca to ensure that your parameters are set just right for the results you want.
If you felt this was helpful, or have any inquiries of your own, please contact us with your questions and feedback!
Click here to order your own from the Onsrud 37-00 series!
Attachment 246738
