585,974 active members*
4,219 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Threadmill with "C"
Results 1 to 6 of 6
    Dec 2003
    17
    Threadmill with "C"
    Has anyone used Gibbscam to threadmill a hole using "X" and "C" axis.
    I don't have a "Y" axis on my sub spindle tool post and would like to produce a 7/16 - 24 internal thread using a .290 dia multi tooth threadmill.
    I can't seem to find anything related to this with Gibbscam.
    If it ain't broke? Your not trying
    May 2012
    83
    Re: Threadmill with "C"
    is it the post you are looking for
    Dec 2003
    17
    No, sorry for the confusion I just don't see anyway to thread mill using the "X" and "C" axis instead of the "X" and "Y" axis in Gibbscam. I do not have a "Y" axis on my machine for the sub spindle where I need to produce the thread. In my earlier statement I said I did not have a "Y" axis on my sub spindle tool post, I meant on the machine itself not my post processor.
    Jan 2006
    2985
    I don't think you'll be able to make a good thread with X and C.
    Turning C changes the thread angle. Also, if your thread is very deep, the top of the hole will hit the shank of the threadmill and break it off when you try to mill the bottom threads..
    Dec 2003
    17
    I know the machine can do it. I have made threads this way manually programming them, it's not hard at all just using "X" , "C" and "Z". I'm just trying to find out if Gibbscam can do this.
    Jan 2005
    15362
    goulyd
    Contact Gibb Cam, there Tec support is very good, I'm sure you will get an answer from them, as you said it's not hard to program it by hand, it is nice though if you can find how to do it in there cam software, for a mill I use there threading all the time, but don't have the Mill Turn package
    Mactec54
  1. Replies: 21
    Last Post: 01-13-2014, 04:10 AM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
