Good Morning, Looking for some help? I am going to thread 1 1/2 6 unc 1b ID thread. Not sure how to set up G76 or G92 cycles in detail. How do you come up with the jump in position for the X value(x before the cycle starts) for either cycle ? And also can you thread with a G76 cycle and then re-thread with a G92 for making dead passes (note using same tool and speed and Z start point). This will be on a Haas lathe.
Thank You
Jeff
