586,031 active members*
2,711 visitors online*
Results 1 to 9 of 9
    Dec 2013
    25
    Thermark suppliers Australia?
    Are there any Australians who use thermark / cermark / alternatives for metal laser marking?
    Trying to find a good supplier preferably locally based or that will ship here.
    Google so far has not been too helpful. Some sites state they will not ship it outside of US which is a pain.
    Or are there any good alternatives to the thermark brand I may not know about?
    Cheers!
    Jan 2008
    940
    Re: Thermark suppliers Australia?
    There was a discussion on Sawmill Creek about using Dry Moly in place of Cermark
    Aug 2003
    494
    Cermark | Laser & Sign TechnologyLaser & Sign Technology
    Cermark - Positive Camtec Pty Ltd
    http://www.engravingsupplies.com.au/..._Materials.pdf
    Just did a Google and this is what I came up with.
    I bought a small bottle of the LM600 and it really goes a long way and lasts really well. Cost me $260 3 years ago.
    Rich.
    I am not completely useless.......I can always serve as a BAD example.
    Dec 2013
    25
    Thanks guys! I didn't realise how much life you could get out of one container. I am lookign into the Dry Moly too. Might be worth experimenting with to see if it is suitable for my applications.
    Cheers!
    Oct 2007
    385
    Ordered a can of CRC Dry Moly and got it today. It was only $10.20 + shipping from Amazon. Worked with it for about 3 hours and finally came up with a decent engraving on both steel and aluminum.. I had to shut off the air assist on my upgraded K40 laser, set the speed to only 10 and the power to about 13ma. Very slow going, but it engraved my open end wrenches quite well. A lot cheaper than any other option. Aluminum was touch and go. If it get overly cold, the Moly just curls up and leaves the metal. One more thing that I have learned since having my laser.
    Milt
    Aug 2003
    494
    I think the settings for the Cermark are at least a 50 watt laser and whatever speed works well but I think it was about 1/3 from memory. My 30 watt laser didn't work well at all on it unless it was very thin metal that didn't suck the heat out of it and run VERY slowly.
    Great to hear the Moly spray works.
    Cermark is certified by NASA for use in space so it can't be that bad. Apparently there are a lot of free O2 molecules in space that like to bind to whatever they touch causing rust/corrosion. never knew that 'till I read it.
    Rich. :-)
    comoon co2 laser is hard to cut metal.
    if yoru metal is less than 1mm, u can add o2 to help laser cut metal.
    the follwoing machine is well to cut metal,diewood, ect DNL-1390 metal co2 laser cutting machine
    Oct 2007
    385
    Am I missing something here? I thought we were having a conversation about marking metal not cutting it.
    Milt
    Aug 2003
    494
    The Chinese do like to advertise any where they can. It must be a prerequisite of the company they work for to saturate the zone with offers. Some just don't know the etiquette.
    I think you can ignore that post. :-)
  1. Thermark on Copper
    By gooch44psi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-12-2014, 03:49 PM
  2. Thermark- is it conductive after lasering
    By cnctoolman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-25-2012, 02:17 AM
  3. LMM14 thermark settings????
    By bpoulin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-02-2011, 04:36 PM
  4. Acme rod suppliers in Australia???
    By paulplaysguitar in forum Australia, New Zealand Club House
    Last Post: 02-27-2009, 09:37 AM
  5. Water based coolant - suppliers in Australia?
    By LeonM in forum Australia, New Zealand Club House
    Last Post: 11-13-2008, 10:51 PM
