584,874 active members*
5,223 visitors online*
    Apr 2007
    16
    Taper Mutistart thread Code
    I am looking if anyone can help out on taper multistart thread codes for GSK928TEa control. I did the multistart thread test on GSK with G76 code but now i want the threads on taper form. Anyone with a solution will be welcome.
    Jun 2009
    12
    Re: Taper Mutistart thread Code
    You need to use G32 for tapper threads.
    See the manual in the link bellow for more information.
    http://www.cncmakers.com/uploads/sof...ser_Manual.rar
    Regards
    Apr 2007
    16
    Thanks Lara for your reply. But G32 is used for tapping cycles. I need multistart thread in taper form. G76 commands is used for this. G76 can handle the thing that i required. For the last two weeks i am working on it. Now i am very near to my goal. I develop the code for taper multistart thread. It only need to test on machine. When i will test it on machine i will surely share the code for others to utilize this.
  1. 1/2" NPT taper thread using G76
    By norfolker in forum G-Code Programing
    Last Post: 07-26-2017, 05:19 PM
  2. Need example of G code taper thread G76
    By woffler in forum Mach Lathe
    Last Post: 10-01-2014, 04:02 PM
  3. NPT Taper-to-Straight-to-NPT-Taper Thread
    By bdyenter in forum MetalWork Discussion
    Last Post: 09-16-2009, 02:10 PM
  4. Thread Milling a Taper
    By automizer in forum G-Code Programing
    Last Post: 06-13-2008, 04:23 AM
  5. taper thread
    By gcrandall in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-17-2006, 04:13 PM
