585,974 active members*
4,384 visitors online*
Thread: Surfcam Post
Results 1 to 20 of 20
    May 2005
    2
    Surfcam Post
    My company is buying an Okuma Lathe (LB3000 EX MYW) with an OSP-P200LA controller. I was wondering if anyone has access to a post for surfcam?
    I contacted Surfcam, waiting on a reply back but don't want to reinvent the wheel. I would like to get a post that is close. Thank you, Rick
    May 2012
    100
    Here, you have two good manuals, especially the Posthaste.
    An ordinary post is easy to configure:
    http://www.cadfamily.com/Download.as...rial&ID=297266
    https://engineering.purdue.edu/AAE/A...Processing.pdf
    But if you send me a file with prefered toolchange, start and end. Cycles etc, maybe i can help you.
    Jul 2005
    56
    Just happened to read your thread and I also was in need of a post for a Fagor 8025TG
    retrofit on a hardinge-gang tool lathe. As you suggested to the other guy;I downloaded 1st PDF but cant get the 2nd. !st time dealing with a lathe and would rather not hand program. Any thoughts !!
    would be appreciated
    JC
    May 2012
    100
    Are you using x- in the machine?
    I am not sure about the post, and i have not fixed the cycles.
    I might need some sample from you, especially tool change. (position)
    Based from: http://www.cms-cnc.com/901-2025.pdf
    Postform.l
    Code:
    name Fagor 8025TG (Inch)
    % 00
    O 5
    N >3
    G >2
    X ->3.>4
    Z ->3.>4
    D 2
    I ->3.>4
    K ->3.>4
    U ->3.>4
    W ->3.>4
    P ->3.>4
    C ->3.>4 Mult 2
    J ->3.>4
    A 60 P
    Q ->4.>3
    q >4 Q
    R ->3.>4
    S >4
    T >2
    t >2
    i 2
    F >3.>6
    M >2
    ModalLetters X Z F M R P S
    ModalGs 0 1 2 3 4 73 76 80 81 82 83 84 85
    First#? N
    Sequence#s N 1 10 10
    Comment ( )
    HCode Z
    VCode X
    FeedCode F
    Spindle 3 4 5
    Coolant 8 9 8
    SpeedType G 97 96
    FeedType G 95 94
    Dcomp 41 42 40
    ByDiameter? Y
    RevX? N
    CtrIncremental? Y
    Inc/Abs G 91 90
    Inch/MM 20 21
    CtrCode K I
    Sbackdoor Supressheader
    Feed G<1>
    Rapid G<0>
    Cw G<3>
    Ccw G<2>
    Leading0s? Y
    UppercaseComments? N
    StartCode
    %<0> O<Program#>
    end
    1stToolChange
    G92 S<Val1>       # Max rpm at G96
    G90 G<FeedType> G<SpeedType> S<Speed> T<Tool> t<Tool> M<Direct>
    G<0> X<V>
    Z<H>
    End
    Linecode
    G<1> X<V> Z<H> F<FRate> M<Cool>
    end
    Infeed
    G<1> G<Side> X<V> Z<H> F<FRate> M<Cool>
    end
    Outfeed
    G<1> G40 C<V> J<H>  # C and J non modal for X and Z
    end
    ToolChange
    i1         # 1 inch safety position and cooling off
    M1
    G<0> X<V>
    Z<H>
    End
    EndCode
    i2            # 1 inch safety position, spindle and cooling off
    M30
    End
    Drill
    G<74> R<Depth>
    G<74> Z<Depth> F<FRate>
    end
    Tap
    G<84> Z<H> F<FRate>
    end cancel
    Ream
    G<85> Z<H> F<FRate>
    end cancel
    Bore
    G<74> R<0>
    G<74> Z<H> R<SClear> F<FRate>
    end
    AutoThread
    G<76> A<TParams> Q<VBite> R<0>
    G<76> X<V> Z<H> R<StartAng> P<Depth> q<Peck1> F<Frate>
    end
    Cancel
    end
    Ask <Val1> "Max Rpm" "500"
    Replace "% " with "%"
    Replace " t" with "."
    Replace "O" with ""
    Replace "C" with "X"
    Replace "J" with "Z"
    Replace "i01" with "G0 Z1. M9"
    Replace "i02" with "G0 Z1. M5 M9"
    Jul 2005
    56
    Fagor 8025TG
    Find attached a program just changed extension to a .txt from .ncc
    Yes using X-..I edit it to speed it up
    This program was hand written as a turnkey and explained to my Boss
    that posting is consistant and alot quicker to do new parts. Again its a
    gang tool lathe..
    JC
    Attached Files Attached Files
    May 2012
    100
    G5 and G7, is it round and square corners?
    When, or with what tool do you use it,
    or do you want to select it at posting?
    It is quite a difficoult post, i also have to figer out about the X-
    I think i can fix that with questions at posting to.
    Jul 2005
    56
    I can send you an IGS file.
    Its a gang tool lathes.
    As far as tools I would pick them at posting but will be using same all the time..Just got in will send soon. Thanks
    JC
    Jul 2005
    56
    Sample part
    Here is the sample part in IGS format and info on tooling stated in a text file. I hope this helps. And definitely
    appreciate the help. First time doing Lathe work. I'm Ok doing mill but of course not going to help now.
    JC
    May 2012
    100
    Ok, so these 2 tools are the only ones to go X-?
    I think i need toolnumbers for all X- tools.
    Aso, what cycles do you use, (Drill, peck tapping) any examples?
    And the start of the program, is that to be all the same, with
    collet etc. *
    %01001
    N10 (REVISED RB 6/21/12)
    N11 (THIS PROGRAM SAME AS 01000)
    N12 (ONLY CHANGES MADE IN IPR)
    N13 (AND RPM TO SPEED PROGRAM TIME)
    N14 G0 G90 G70 G7 T2.2
    N15 G53 (OFFSET)
    N16 G0 X.25
    N17 (Z.15 ORIGINAL Z OFFSET)
    N18 G0 Z.110 (NEW Z OFFSET)
    N19 M0 (PULL PART TO STOP AND CLOSE COLLET)
    N20 G0 Z.35
    I give it a try later in week.
    May 2012
    100
    Try this for your turning tools, if i guess right you use only T1 and 2
    for outside turning?
    I am not sure about Gside and Interpolation at RevX,
    and you have to draw and process your work normal in
    Surfcam, (X+) it dont seem to work smowley to draw in X- as your example show.
    As the post is made now, T1 and 2 (only outside) is going to be RevX and Gside
    (Nose radius Compensation) is reversed.
    Your offset is set to ask you, and Collet is set to close and open with
    M10 and M11. Also i added max rpm for G96, if you use that. G5 ang G7 for
    rough and precision is also added. But why G53 only?
    Never use G54?
    Gome back, i am probebly not finished.
    Code:
    % 00
    O 5
    N >3
    j 2
    G >2
    X ->3.>4 Mult 2
    Z ->3.>4
    B ->3.>4 Mult 2
    E ->3.>4
    D 2
    I ->3.>4
    K ->3.>4
    U ->3.>4 Clamp 0.001 0.3
    W ->3.>4
    P ->3.>4
    C ->3.>4 Mult 2
    J ->3.>4
    A 60 P
    Q ->4.>3
    q >4 Q
    R ->3.>4
    S >4          # SET YOUR SPEED LIMIT. EX: S >4 Limit 20 6000
    T >2
    t >2
    i 2
    F >3.>6    # SET YOUR FEED LIMIT. EX: F >3.>6 Limit 0.0001 15
    M >2
    u 2
    ModalLetters B E X Z F M R P S
    ModalGs 0 1 2 3 4 40 41 42 70 73 76 80 81 82 83 84 85
    First#? N
    Sequence#s N 1 1 10
    Comment ( )
    HCode Z
    VCode X
    HCode2 E
    VCode2 B
    RevSigns B
    FeedCode F
    Spindle 3 4 5
    Coolant 8 9 8
    SpeedType G 97 96
    FeedType G 95 94
    Dcomp 41 42 40
    CtrIncremental? Y
    Inc/Abs G 91 90
    CtrCode R
    Feed G<1>
    Rapid G<0>
    Cw G<3>
    Ccw G<2>
    Leading0s? N
    StartCode
    %<0> O<Program#>
    end
    1stToolChange
    if <Tool> = 1 or <Tool> = 2    # TOOLS TO GO REVX
    set <Turret> to 2
    else
    set <Turret> to 1
    endif
    i4
    M1
    if <Tool> = 1
    j1 G7 T<Tool> t<Tool>      # G7 BLOCK DECELERATION CHECKING ON
    endif
    if <Tool> = 2
    j1 G5 T<Tool> t<Tool>      # G5 BLOCK DECELERATION CHECKING OFF
    endif
    if <Tool> <> 1 and <Tool> <> 2  # TOOLS NOT TO GO REVX
    j1 T<Tool> t<Tool>
    endif
    j2
    set <Val2> to 0.11
    U<Val2>
    i3
    M10 u1                     # COLLET CLOSE. REMOVE THIS LINE IF YOU DONT WANT IT
    G0 Z.35
    if <SpeedType> = 96
    Ask <Val1> "Max Rpm" "1000"
    G92 S<Val1>
    G<FeedType> G<SpeedType> S<Speed> M<Direct>
    else
    endif
    G<0> X<V>
    Z<H> F<FRate>
    End
    Linecode
    G<1> X<V> Z<H> M<Cool>
    end
    Infeed
    set <Side> to 41
    endif
    G<1> G<Side> X<V> Z<H> M<Cool>
    end
    Outfeed
    G<1> G40 X<V> Z<H>
    end
    ToolChange
    set <Turret> to 2
    else
    set <Turret> to 1
    endif
    i1
    M1
    if <Tool> = 1
    endif
    if <Tool> = 2
    endif
    j1 T<Tool> t<Tool>
    endif
    G53
    if <SpeedType> = 96
    G92 S<Val1>
    else
    endif
    G<0> X<V>
    Z<H> F<FRate>
    End
    EndCode
    i2
    M11 u2              # COLLET OPEN. REMOVE THIS LINE IF YOU DONT WANT IT
    M30
    End
    Drill
    G<74> R<Depth>
    end
    Tap
    G<84> Z<H> F<FRate>
    end cancel
    Ream
    G<85> Z<H> F<FRate>
    end cancel
    Bore
    G<74> R<0>
    end
    AutoThread
    end
    Cancel
    i1
    end
    Ask <Val2> "Wp offset?" ".11"      # WP OFFSET. REMOVE THIS LINE IF YOU DONT NEED IT. DEFAULT IS .11
    Replace "O" with ""
    Replace "B" with "X"
    Replace "E" with "Z"
    Replace "U" with "Z"
    Replace "i03" with "M0 (PULL PART TO STOP AND CLOSE COLLET)"
    Replace "i04" with "G0 G53 Z1."
    Replace "j01" with "G0 G90 G70"
    Replace "j02" with "G0 X.125"
    Replace "u01" with "(COLLET CLOSE)"
    Replace "u02" with "(COLLET OPEN)"
    Jul 2005
    56
    I will give a try assisting with more info I only have one program (hand written) to work from and thats
    the one I sent you. I have no examples of dril,peck or tapping. The gang lathe at this point will only have tools 1and 2 and this clamping device which is tool 3. Im attaching info that may assist. G53 not sure why
    It seems nobodys fault each programmer writes a different way. Thats why these issues. I will get back.
    Thks again
    JC
    Exclamation
    Hi there:
    I just get here, and after seeing the pictures you posted, I realized why the problems having to use Turn ID in the OD and going on with the post.
    You are drawing the part backwards. No matter what kind of machine you have. It can be a parallel, gang-tool, turret, or vertical lathe; SURFCAM is configured in such a way that you MUST draw your job from X 0 towards the plus direction; and then let the post-processor take care of changing directions, like X…..Mult -1.
    If you do this, SURFCAM will care about your Side (G41-42), nose radius compensation, interpolation and so on.
    You are doing a good job in the post with many IF – Then that really don’t need, SURFCAM will cover all that.
    Kind regards
    Mario
    May 2012
    100
    Team-Mgn What kind of company is that by the way? :violin:
    Jul 2005
    56
    tested post
    Mario,
    Thanks for the response back, appreciate the comments. I tried the post and got an error which I sent you as a JPG for you to read. Just to let you know the previous post that you had up earlier in your first thread I tried it and posted out. I may be doing something wrong with this one not sure..
    JC
    Jul 2005
    56
    Mario,
    Thanks for the comment I got carried away with the visual on the backplot. I tried the post and recieved an error. I sent it as a jpg for you to read. The first post you had up on the thread (8025TG inch) I tried and it posted out.
    I may have done something to cause error - not sure.
    JC
    Jul 2005
    56
    Thanks for the comment got lost trying to make it work and also trying to visualize
    tool position.
    May 2012
    100
    You probebly removed the space betwen % and 0
    at format, in line 2.
    This is right
    % 00
    This is wrong
    %00
    Spaces is very important in the post, no space, no posting and
    one to mutch, wrong code.
    Mirror your work and process in X+ direction, that is the way to go.
    The post will reverse the code for tool 1 and 2 only.
    Jul 2005
    56
    OK
    Oct 2014
    2
    Re: Surfcam Post
    I'm new to cnc programming and I need a siemens 810 post processor for surfcam v4.
    Any sugestions?
    Sent from my GT-S7710 using Tapatalk
    May 2013
    142
    Re: Surfcam Post
    Code:
    name Siemens 810M
          # Modified added RapidCode logic sequence 3/27/2014
    % 00
    / 00
    O >4
    N >4
    G >2
    g >2 G
    X ->3.>4
    Y ->3.>4
    Z ->3.>4
    A ->3.>4
    I ->3.>4
    J ->3.>4
    K ->3.>4
    Q ->3.>4
    R ->3.>4
    P >40
    F >3.1
    H >2
    D >2
    T >2
    M >2
    S >4
    ModalLetters X Y Z F R                # List of letters that are modal
    ModalGs 0 1 2 3 73 74 76 80 81 82 83 84 85  # List of g codes that are modal
    Sequence#s N 0 1 1                    # Char, freq, incr & start
    First#? N                             # Y or N  'Output 1st sequence no.
    Last#? N                              # Y or N  'Output last sequence no.
    HCode X                               # X or X U  'Horizontal char.
    VCode Y                               # Y or Y V  'Vertical char.
    Dcode Z                               # Depth char.
    FeedCode F                            # Feed rate char.
    Comment ( )                           # Begin End comment char.
    Spindle 3 4 5                         # Cw, ccw & stop m codes
    Coolant 8 9 7                         # On, Off & Mist m codes
    DComp 41 42 40                        # Left, Right & Cancel m codes
    LComp 43 49                           # On & Off codes
    Feed G1                             # Linear move
    Rapid G0                            # Rapid positioning word
    Cw G2                               # Circular move clockwise
    Ccw G3                              # Circular move counter clockwise
    ArcToLineWarnings? Y                        # Small Arc Warnings
    MinArc .0099                                # MinArc Default = .0099
    MinRad .005                                 # MinRad Default = .005
    Inc/Abs G 91 90                       # Inc & Abs char. & values
    CtrCode I J                           # I J or R or I J K L
    Helical? N
    Spaces? Y                             # Y or N  'Spaces between words
    Incremental? Y                        # Y or N  'Inc or abs output
    CtrIncremental? Y                     # Y or N  'Inc or abs I & J
    ByQuadrants? N                        # Y or N  'Break arcs at quadrants
    UppercaseComments? Y                  # Y or N 'Require uppercase comments
    Drill                                 # Drilling canned/manual cycle
    G81 X[H] Y[V] Z[D] R[Vclear] F[FRate]
    end cancel
    Peck                                  # Pecking canned/manual cycle
    G83 X[H] Y[V] Z[D] Q[VBite] R[Vclear] F[FRate]
    end cancel
    Tap                                   # Tapping canned/manual cycle
    G84 X[H] Y[V] Z[D] R[Vclear] F[FRate] Q[VBite]
    end cancel
    LTap                                  # Left handed tapping cycle
    G74 X[H] Y[V] Z[D] R[Vclear] F[FRate] Q[VBite]
    end cancel
    Ream                                  # Reaming canned/manual cycle
    G85 X[H] Y[V] Z[D] R[Vclear] F[FRate]
    end cancel
    Bore                                  # Boring canned/manual cycle
    G86 X[H] Y[V] Z[D] R[Vclear] F[FRate]
    end cancel
    Back                                  # Back boring canned/manual cycle
    G87 X[H] Y[V] Z[D] R[Vclear] F[FRate]
    end cancel
    Cancel                                # Cancel a canned/manual cycle
    G80
    end
    RapidCode                                   #(Include 'Z safety' logic)
    Comments
    IF [D] < [LastD]                            #Going down?
     G0 X[H] Y[V]                               #XY first,
     Z[D]                                             #then Z.
     exit
    ENDIF
    IF [D] > [LastD]                          #Going up?
     G0 Z[D]                                    # Z first,
     X[H] Y[V]                                  # then XY.
     exit
    ENDIF
    IF [D] = [LastD]
    G0 X[H] Y[V]
    exit
    ENDIF
    END
    StartCode                             # Start of the program
    %0
    O[Program#]
    "(MACHINE: " {TemplateName} {TemplateExt} " MPOST Library)"
    G90 G80 G40 G17
    End
    1stToolChange                         # First tool change
    T[Tool]
    M6
    M[Direct] S[Speed]
    G90 G0 G[Work] X[H] Y[V]
    G43 Z[D] H[Lcomp]
    M[Cool]
    End
    Infeed                                # Enable cutter comp
    G[Side] X[H] Y[V] D[DComp] F[FRate]
    end
    Outfeed                               # Disable cutter comp
    G1 G40 X[H] Y[V]
    end
    ToolChange                            # Secondary tool changes
    M9
    g91 G28 Z0 M5
    M1
    T[Tool]
    M6
    M[Direct] S[Speed]
    G90 G0 X[H] Y[V]
    G43 Z[D] H[Lcomp]
    M[Cool]
    End
    Upon [Speed]                                # Output spindle speed change
    M[Direct] S[Speed]
    End
    EndCode                               # End of the program
    M9
    g91 G28 Z0 M5
    T[Tool1]
    M6
    G90 G0 X0 Y0
    M30
    %0
    End
    This is the stock one straight out of the library.
  1. Surfcam Post Citizen
    By dmschell in forum CNC Swiss Screw Machines
    Last Post: 08-18-2010, 08:00 AM
  2. Surfcam post?
    By Lasershop in forum Centroid CNC Control Products
    Last Post: 02-09-2009, 08:35 PM
  3. Surfcam post for g71
    By villiersterrace in forum Haas Mills
    Last Post: 08-03-2006, 12:44 AM
