I intend building the Solsylva 10 x 9 CNC machine. I have 3 Nema 23 stepper 5 lead motors rated as follows:
Rated Voltage = 3.6V
Current 2A
Phase Resistance = 1.8 ohm
Step angle 1.8 deg
Holding Torque 9kg/cm
If I use a 12v power supply I presume I will have to use a dropper resistor. Will this resistor be 12V/2A = 6 ohms to limit the current to 2A and will this resistor be connected to the common lead?
I have a controller from Chromation Systems.
Apologies in advance if I have posted this in the wrong place !
