585,729 active members*
4,792 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Stacked precision boring adapter in mills taper
    Nov 2006
    12
    Hi , I have quantum bf20l mill.
    I tyr my new presicion boring tool in it's mt2 taper. But it stacked in mt2. same happen before er25 collets too.
    Now hot to remove it ? and ideas for avaid it again ?
    Nov 2006
    12
    Re: Stacked precision boring adapter in mills taper
    I missed the screw mechanism under the plastik hood.
    Solved
    Jun 2010
    4256
    Apply high tension to pull it out. You won't succeed, but the tension is important.
    Then tap the top end of the pull rod.
    Caution: have a large cushion underneath ready to catch the fitting.
    Next time, use some copper anti-sieze on the mating faces.
    Cheers
  1. Smooth Shank no taper chuck adapter
    By magudaman in forum CNC Tooling
    Last Post: 08-09-2013, 04:36 PM
  2. J609 taper - specs - boring - adapter
    By gpk9 in forum MetalWork Discussion
    Last Post: 08-20-2012, 07:22 PM
  3. How to machine an adapter to convert taper shaft to straight
    By kola in forum MetalWork Discussion
    Last Post: 07-15-2011, 04:39 PM
  4. 30 MM Spindle Taper Adapter
    By JVAvitech in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-12-2007, 11:04 PM
