I have been using the "Transformation" function to do multiple operations in my multi part programs, everything worked fine until I tried to use it for tapping, there it doesnt work or I have a setting wrong etc,
Path pilot doesnt like the code it outputs, it has an F0 in a line of code for each op for some reason??
I like the Transformation op as I dont have to select the curves etc on each part, but I cant get it to work with the tapping op. I was wondering if any of you have had a similar issue?
thanks
