Hi Everyone!
Hoping you can shed some light.
I ordered a motor that has an encoder attached to it. I plan on using it for my G0602 cnc build.
My question is, is there anything that this encoder is useful for in this application or did I waste money?
I know that typically the encoder should be on the spindle, not the motor. If I were running a 1:1 pulley ratio it would seem to make more sense, but Im not sure if whatever is accepting the signal (which im not sure of, vfd, mach3, ??) can be adjusted to read how fast the spindle is running based on motor rpm.
I plan to use a Teco JNEV VFD and Mach3.
Here is the encoder in question:
Series HS20 Sealed Hollow Shaft Encoders - Dynapar Incremental Encoders
And here is the motor:
Y284, 145THTR15540, 1 1/2 Hp, 230/460,145TC FR,1800 Rpm,1024 PPR
Thanks for the help!! Im sure Ill have plenty more questions as this build progresses.
