Originally Posted by
alan_3301
I think with any cam program with a machine that complex you will have to pay for a post processor that will tell the cam program how to output code for the machine.
The material and machine will determine what speeds and feeds are appropriate, simulation time should be pretty accurate, though if the cam program doesn't account for axis acceleration, it would be off some amount.
Imachining is for milling only (I think), it spirals down to the full cutter depth, and uses a constant stepover pattern, so that tool load is fairly constant while cutting.
This decreases machine time, and is easier on cutters.
