585,754 active members*
3,915 visitors online*
Results 1 to 2 of 2
    May 2014
    19
    Slipping Coupling
    I got couplings similar to the one in the link, but made from aluminium instead. In the past I had only negative experience with these kind of couplings that clamp the shaft. Do you think I need to modify them to make them work? Add a grubscrew, use lock tight or roughen the surface? At the moment both shaft and coupling are shiny smooth. I am worried because if one coupling slips, something will break.
    My CNC uses Nema 24 steppers and 8mm Pitch lead screws.
    http://www.cnczone.com/forums/linear-and-rotary-motion/
    Mar 2006
    2712
    Re: Slipping Coupling
    Your link doesn't work for me. What kind of coupling are you referring to?
    Dick Z
    DZASTR
  1. Z Axis slipping
    By neomagik in forum DIY CNC Router Table Machines
    Last Post: 06-11-2021, 07:56 AM
  2. Slipping Axis
    By Dingo745 in forum Australia, New Zealand Club House
    Last Post: 04-04-2013, 03:41 PM
  3. Rigid Coupling Vs. Flex Coupling
    By Johnsnd in forum DIY CNC Router Table Machines
    Last Post: 05-30-2009, 03:25 PM
  4. x axis slipping
    By FUN4ME in forum Fadal
    Last Post: 01-08-2008, 09:20 PM
  5. Y Axis Slipping ??
    By twocik in forum Benchtop Machines
    Last Post: 12-12-2007, 12:11 AM
