I have my engraver up and running, but when I engrave a name the letters are all slanted? Does anyone know what would cause my design to come out slanted? It is straight along the bottom, but each letter is tilted? Thanks, stephanie
check your belts they may be a little loose and your head moves over just a little each pass
Thanks. We checked all the belts and they are all tight. Letters are still slanted?
Only reason is that y rails are not 90deg to x rail. You'll need to adjust by loosening screws and re-tighten.
Here's an lesson from Thunder Laser may help you:
Why engraving edge out-of-straight
good luck.
www.thunderlaser.com
