I am having a weird problem with a file I have been working on in Design Elements.
I exported a multipart dxf and converted it into a usable file. All of the parts except one worked just fine, but the one absolutely refuses to extrude properly. When I extruded the plate only some of the holes are cut out. I have tried multiple things to solve the problem: I tried deleting and redrawing parts in the sketch. I have tried copying good objects but the duplicates don't work. I have tried separating the parts into separate sketches to no avail. I have tried analyzing the sketch and it passes. However if I draw a box around the object it renders perfectly (except it's reversed of course)
Anyone have any idea on what to check to see where the problem is?
