586,013 active members*
4,159 visitors online*
Results 1 to 2 of 2
    Feb 2005
    487
    Shuttle Pro Plugin mod!!!
    Greetings,
    OK, those of you with a Shuttle Pro please test this plug in.
    I added 10 total custom macros, and I added a "Reverse Axis" option for Axis X-C.
    Let me know how the Reverse axis works, since there is another section of code that deals with jogging, but I think it is for something different, could be wrong of course.
    Remember to save out your current shuttle pro .dll
    Here is the link:
    http://www.machsupport.com/forum/ind...c,1220.80.html
    reply #88 (near the bottom of the page), has the New shuttle pro .dll
    The 10 custom macros work, just need a tester to varify the "Reverse" axis check boxes.
    scott
    Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
    Feb 2005
    487
    Ok, I have attached, the debugged version II of the shuttle pro pendant for you if you wish to upgrade. It has be tested by the mach support community and all is working as it should.
    Total of 10 Custom Macro's now
    Added Independant Axis reversals for all 6 axis.
    Note: since I had to follow Arts numbering convention, the 6 extra macros are at the end of the 800 series list, this will bump down all OEM code indexes by 6, so any buttons you have assigned to OEM codes you will need to Re-assign.
    To install:
    you will need to open the zip file to your desktop and then if your
    running the standard Tormach install directory, navigate to it, and copy and paste the, "ShuttlePro.dll", into your plugins directory.
    DON'T double click the, "ShuttlePro.m3p", shuttle pro unless your running standard mach3 in its usual directory, if that is the case then double click the shuttlepro.m3p and it will auto install into the standard mach3 directory.
    scott
    Attached Files Attached Files
  1. Shuttle Pro Problem
    By shane.vella in forum Mach Wizards, Macros, & Addons
    Last Post: 07-16-2012, 01:17 AM
  2. shuttle pro/ video showing mpg
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 04-23-2009, 04:23 AM
  3. Shuttle Pro and Mach R3.042.020
    By dsage in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2008, 11:27 PM
  4. Shuttle In Problem
    By CountBraden in forum Haas Mills
    Last Post: 08-24-2008, 05:57 AM
  5. VF3 SHUTTLE IN FAULT
    By JACKOFTRADES in forum Haas Mills
    Last Post: 11-29-2007, 05:23 PM
