585,898 active members*
5,079 visitors online*
Results 1 to 2 of 2
    Sep 2006
    69
    Servo Tuning HELP!!
    Hello all,
    I have a 3 axis VMC with Vickers acromatic A2100 control. Just recently the X axis has started making a high pitched resonance noise while moving, this continues for a short time even when the axis is stationary. I assume the servo drive needs tuning(siemens simodrive). Can anyone help me with this? I would like to connect my laptop to the drive and run an Autotune but am unsure how to do this and what software to use.
    Any help would be much appreciated
    Thankyou
    Jan 2007
    229
    Good luck!
    What sort of drives control the servos?
    Are they tunable manually, (screwdriver on a pot) or is there a setting in your software somewhere to adjust the P,I & D settings- if so what are they at the moment?
  1. VF-2 servo tuning
    By Rstewart in forum Haas Mills
    Last Post: 12-20-2018, 02:22 PM
  2. Servo tuning
    By bmlw in forum Daewoo/Doosan
    Last Post: 05-13-2010, 02:57 PM
  3. 6t Servo tuning?
    By Jerry Shorter in forum Fanuc
    Last Post: 08-17-2009, 11:28 PM
  4. SERVO TUNING
    By Capteod in forum Servo Motors / Drives
    Last Post: 09-17-2008, 04:46 AM
  5. appropriate servo tuning.... help?
    By howling60 in forum Servo Motors / Drives
    Last Post: 02-27-2006, 03:48 PM
