586,009 active members*
4,913 visitors online*
IndustryArena Forum > CAM Software > Vectric > Scaling problem with MACH3
Results 1 to 8 of 8
    Aug 2014
    5
    We are in the process of building a small CNC 3 axis milling machine that relies on MACH 3 to control it. Both the X and Z axis work perfectly but the Y axis does not. The scale is not correct but what is worse is that it depends upon which direction it is moving. For example If I tell Mach3 to move the Y axis 40 mm it moves 45 mm and if I tell it to move - 40 mm it moves 35 mm.
    I can confirm that there is no problem with the stepper motor as I have replaced the old one with a NEMA 17 from a Rotalink one with the same problem. I have tried both a Stepstick driver and an Easydriver with precisely the same results. Perhaps I have accidentally adjusted some settings on the MACH3 program without realizing.
    I would be grateful for any help regarding this problem.
    May 2010
    41
    Re: Scaling problem with MACH3
    Double check your "steps per" in Config>motor tuning.
    At what microsteps are you running on the drivers?
    KL-4530 CNC, KL-6060, 5 3D printers, CNC Fusion Converted LMS Milling Machine, 60w Laser Cutter
    Aug 2014
    5
    Hello Sockles,
    The steps per is set to 1600. My lead screw pitch is 1 mm and my y stepper motor rotates in 1.8 degree segments with added resolution of 8 times micro-stepping. However whatever my steps per is it does not account for the difference in distance travelled depending upon the direction.
    35538
    Are you in absolute mode?
    If your at Y = -5
    and do a G0 Y40, it will move 45mm.
    If your at Y = -5
    and do a G0 Y-40, it will move 35mm.
    If you do a G91 for incremental mode, then the above code will move 40mm each way.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2014
    5
    I shall try this but it is not always 5 mm out because if it were told to move 20 mm it would probably be 2.5 mm out but I may be wrong. Thank you for your feedback Ger21.
    Jan 2005
    15362
    Quote Originally Posted by Shed123 View Post
    Then set the steps per for that axes, they are not set correct
    Open Settings Tab, Then Just above the Reset Button, you can do your axes calibration from there, just follow the instructions, & you will get it as perfect as you want it, depending on the method you use
    Mactec54
    Aug 2014
    5
    Unfortunately this did not solve the problem. I did notice that in the general config window I had the "Perform G92.1" box ticked. I have had a general look around on the internet for anybody who had a similar problem to this one but have found no-one.
    Aug 2014
    5
    I may not be making this quite clear. The distance that the Y axis moves is dependent upon it's direction. I could not work out a way to make the Steps per to be correct in both directions.
  1. PCB Scaling problem
    By negativ3 in forum PCB milling
    Last Post: 07-24-2014, 08:06 PM
  2. Mach3 PROBLEM!!!
    By bowtechmatthew in forum Mach Software (ArtSoft software)
    Last Post: 12-03-2012, 12:20 AM
  3. CamBam or Mach3 Scaling/Shrinking Drawings?!
    By catabolic in forum CamBam
    Last Post: 07-12-2011, 07:22 PM
  4. Mach3 problem with new cnc
    By jimmyaz in forum DIY CNC Router Table Machines
    Last Post: 06-04-2011, 12:38 PM
  5. Scaling problem
    By kentigens in forum LinuxCNC (formerly EMC2)
    Last Post: 03-24-2009, 02:34 PM
