585,560 active members*
3,298 visitors online*
Results 1 to 4 of 4
    Jul 2014
    4
    Saving Sttings
    Just purchased a TM-1. The owner told me that every time the machine is powered on, you need to go to settings 51 and change it. This is the setting to keep from having to use the hand held hold to run button. Is there no way to make the machine save this setting so it doesn't need to be changed every time the machine is powered up?
    Feb 2010
    1184
    Re: Saving Sttings
    Quote Originally Posted by jonathanrayce View Post
    No, it must be reset every time. Pretty soon it will become automatic and will not bother you anymore.
    Mar 2010
    1852
    Re: Saving Sttings
    Quote Originally Posted by haastec View Post
    It is a routine that becomes automatic, takes me about 3-4 seconds each morning. Just be thankful that you have an older machine, on newer machines it is not even available!
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Dec 2011
    295
    Re: Saving Sttings
    The idea of that button is a good one, but the implemention not so much. Cut off the switch and rewire with a normal closed button ( somewhat difficult to source). Now you will have a junior remote pendant with E STOP capability. More intuitive. Paint it red.
  1. Saving g54
    By BOATDUDEGUY in forum Mach Software (ArtSoft software)
    Last Post: 02-19-2014, 02:08 PM
  2. dxf saving
    By t_chance in forum Surfcam
    Last Post: 10-15-2013, 08:06 PM
  3. saving to a dwg.
    By pchfurniture in forum BobCad-Cam
    Last Post: 01-15-2012, 02:17 PM
  4. saving files with a DWG or DXF
    By casta-baga in forum Mastercam
    Last Post: 08-07-2008, 04:02 AM
  5. Saving the Changes,
    By CharlieM in forum Uncategorised CAM Discussion
    Last Post: 01-11-2006, 08:24 PM
