586,030 active members*
2,985 visitors online*
Results 1 to 5 of 5
    Jul 2014
    4
    Question removing stock too early
    Hi there,
    so, I am using the trail version of meshcam and I tried to convert this object to gcode:
    As you can see, I set the stock size a bit bigger than the object itself. I did this because I want to cut this piece out of a bigger piece of MDF wood.
    My problem is that the gcode of meshcam first cuts the piece out of the bigger stock before it machines the inner part. How do I change this sequence?
    Thanks.
    Jul 2007
    1602
    Re: removing stock too early
    Meshcam isn't really the best program to use for this. It's strength is true 3D while your part is 2.5D. A 2.5D CAM such as CamBam or SheetCam are much better suited for this part.
    bob
    35538
    You can set machining regions and output separate g-code for the inside and outside portions.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2014
    4
    Okay, thanks both! I just got back from holiday and tested cambam.
    When I load the same stl file in cambam and produce gcode, I get this path:
    As you can see, it wants to turn the complete internal rectangle into dust by milling everything. I have no idea how I can let it just cut out the border of the rectangle. Does anyone of you know? I don't want to draw this object with cambam itself.
    I hope it's not a problem that I ask this question in here. Otherwise, sorry .
    Jul 2007
    1602
    It looks like you specified a pocketing operation for the inside. Use a profile operation and it should work fine.
    b0b
  1. Early Zen works 7x7
    By Skysurfer in forum Zen Toolworks
    Last Post: 12-07-2013, 02:50 PM
  2. Removing aluminum stock fast or drill vs end mill...
    By zaebis in forum MetalWork Discussion
    Last Post: 09-04-2009, 05:03 AM
  3. Removing stock around part--beginner questions
    By jlembas in forum Mastercam
    Last Post: 02-06-2008, 03:36 PM
