Good morning gang,
TGIF
Wiring up the VFD signal lines as the final steps today: I have a huanyang 220 3Hp two leg to 3 phase. Trying to map this over to my VFD. I'm still new to ChinEnglish and Industrial controls. Your AD-GS2 looks similar so I'm referencing your Tech Bulletins. Nice to find those btw!
From what I can tell, The Huanyang setup for me is:
1) The FWD, RVS, Fault (RST) & DCM lines. (Image included below) are a match to the GS2.
2) for the DAC DC-Aio shielded lines: Those should utilize the AI and ACM terminals on the Huanyang.
Note- AI on this unit has 4 analog modes. Pd0070=0 for 0to10v operation. There is also a VI terminal for analog 0-10V but I did not see a PD code reference on it?
Here is where I'm sort of stuck.
3) To map the R2/O fault equiv from the GS2 to the Huanyang is where I'm a bit confused? The Huanyang has 3 Multi-outputs. NO or NC as FC,FA,FB. PD0052 notes that : "Terminals of FA, FB,FC PD0052 0=invalid, 1=Run, 2=Zero Speed, 3=Fault Indication, 4=Braking, 5, 6,7,8 etc...
So I think I set PD0052=3 and wire FC terminal to H10/10. Not sure what is a common there?
Attachment 270460
Automation Direct GS2 setup.
L1, L2, L3 - 3 phase power in
DI1 - Forward run
DI2 - Reverse run
DI4 - Fault reset
DCM - Input common
AI - Master speed frequency reference (0-10vdc)
ACM - Frequency reference common
R2O - Fault output (normally open)
R2 - Fault output common.
T1, T2, T3 - Motor voltage out
B1, B2 - Braking resistor (up to 15hp)
