585,926 active members*
3,941 visitors online*
Results 1 to 4 of 4
    Sep 2005
    272
    PUMA 240 LATHE
    2006 daewoo puma 240 fanuc 21ITB wondering how people are using the tool set button on the control panel? the book says you can change a parameter so it will work for picking up the part length(Z) anybody doing this? if so does it use the work shift and not the G54-G59? rite now I use the button for setting tools when I'm not using the Q setter, indicating drills ect.it will set the machine position number(G53) in the geometry page regardless if there is a offset called up or not when using the X0 measure on the soft screen. I guess what I'm trying to say is there a way to pick up the Z0 work shift with this button like a mori seiki lathe?
    Nov 2013
    65
    Re: PUMA 240 LATHE
    I call up the tool G54 T0101 then move to where I want to set Z zero. You have to have to Z G54 number highlighted then type Z0 measure and boom it changes the G54 work shift to where your sitting at when you do this. If I understand what you are asking.
    Brent
    Sep 2005
    272
    Re: PUMA 240 LATHE
    yes I do that also, but was talking about the tool set button on the control panel
    Nov 2013
    65
    Re: PUMA 240 LATHE
    I guess I misunderstood your question. My 240 is a newer Doosan I don't think I have that "tool set" button. I'll look again today.
    Brent
  1. PUMA 2000SY LATHE
    By VALBYRNES in forum Daewoo/Doosan
    Last Post: 01-08-2015, 04:02 PM
  2. Daewoo Puma 400 Lathe
    By TURNER in forum Daewoo/Doosan
    Last Post: 08-23-2012, 02:16 PM
  3. Puma 12L Lathe
    By ccrow2000 in forum Daewoo/Doosan
    Last Post: 01-13-2009, 08:28 PM
  4. Daewoo Puma 700 LM lathe
    By Norboy in forum Daewoo/Doosan
    Last Post: 07-10-2008, 06:35 PM
  5. Daewoo Puma 700 LM - Lathe
    By Kim in forum Daewoo/Doosan
    Last Post: 04-18-2008, 07:18 PM
