585,954 active members*
4,111 visitors online*
IndustryArena Forum > CNC Electronics > DeskCNC Controller Board > Proximity switches with optocoupler adapter
Results 1 to 16 of 16
    I am replacing my MultiCam 22Plus CNC controller and some of the other parts with a Planet CNC controller.
    My proximity switches for the three axis will require an "optocoupler" between the limit switch connection on the controller board and the proximity switch.
    I have five proximity switches, 2 for "X axis", 2 for "Y axis", and 1 for "Z axis", My question is, can I wire the proximity switches for the two "X" switches in a series and the two "Y" switches in a series or does each switch require it's own optocoupler?
    Thanks in advance
    Jim Markevitch
    Grapevine, TX
    Dec 2003
    24221
    Re: Proximity switches with optocoupler adapter
    You can stack or AND opto outputs, but why do you need opto's?
    Al.
    Albert E.
    Thank you. My limit switches are PNP 3-wire units, not the mechanical type. The optocoupler adapter are not built in the controller.
    May 2011
    37
    Quote Originally Posted by Jamesdee View Post
    Hi,,, can someone people's by this forum, help to find me scheme wires of board optocoupler ? I have a picture only and the copper wires it's partially visible..
    I need use this optocoupler pcb for use with proximity sensors..
    Dec 2003
    24221
    Albert E.
    Jan 2005
    1943
    I just wired my 3 wire PNP's to small relays I got from Radio Shack and that has worked great.
    May 2011
    37
    Quote Originally Posted by 109jb View Post
    I have already schematic 2530 IC. I need of pcb schematic copper wires for rebuild this board same to picture. I need know wires hidden under IC 2530. The two resistors value 33,000 ohms, it have a copper wires .Which are the linked pins IC ?
    May 2011
    37
    can someone help to find me schematic diagram of this pcb?
    Dec 2003
    24221
    It should be Very easy to reverse engineer?
    Use a meter to find common traces.
    Al.
    Albert E.
    May 2011
    37
    Quote Originally Posted by Al_The_Man View Post
    Al.
    Hello Al_the_man, I haven't the pcb physically, I need of build homemade and I have only pictures of this pcb. I need know of schematic wires . Can you find the non visible wires from picture? I need know as the two red resistors it's linked with whitch pins IC .
    Dec 2003
    24221
    Well the continuity test will tell you!
    It looks like both 2.2k are fed off of the supply, pin 8, and each 2.2k are the load resistors on each output pin, 7 & 6.
    It is a very simple circuit to R.E.
    Al.
    Albert E.
    May 2011
    37
    Al.
    Thanks Al_the_man,, unfortunally I am not very prepared for theoretical electronics.
    Can you put here a sample draw diagram of wires so I can understand ?
    I have posted a two picture diagram the first is a IC 2530 optocoupler and the second as it will work with controller cnc and proximity swith limit..
    thanks again
    Attached Thumbnails Attached Thumbnails schema 2530.png   optocoupler pcb adapter.jpg
    May 2011
    37
    if this can help I have posted a schematic of 2530 IC
    May 2011
    37
    hello. someone can help me for solve this question ??
    Dec 2003
    24221
    Here is a simple opto circuit using 4n35 etc.
    The 330 ohm resistor would need to be changed for higher input supply voltage.
    Al.
    Albert E.
    May 2013
    3
    Quote Originally Posted by walkit View Post
    Hi my friend. After this time, do you have the complete schematic? I'm with the same problem.
    Thanks.
  1. Looking for Proximity switches.
    By Marwell in forum Want To Buy...Need help!
    Last Post: 01-08-2009, 10:42 PM
  2. PROXIMITY SWITCHES
    By CHANDRU in forum CNC Machine Related Electronics
    Last Post: 12-12-2007, 02:33 PM
  3. proximity switches
    By woodguy7777 in forum Commercial CNC Wood Routers
    Last Post: 04-29-2006, 10:17 PM
  4. Proximity switches
    By bgriggs in forum DIY CNC Router Table Machines
    Last Post: 09-01-2003, 06:13 AM
  5. proximity switches
    By rcrabb in forum DIY CNC Router Table Machines
    Last Post: 07-21-2003, 05:27 AM
