586,030 active members*
2,746 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > Proma THC & Hypertherm Powermax 45, faults in test mode. Bad power supply?
    Apr 2013
    5
    I have a Proma compact THC & Hypertherm Powermax 45 that I am using with Mach5. I got things wired up and largely working. For the power source to the HTC, I cut up an old cellphone charger and wired into a powerstrip.
    When I run the THC's test mode, mach5 faults and triggers e-stop. My guess here is that I need to get power, not from a separate source, but one that pull directly from the hypertherm. If that is true, can someone share a diagram, photo or simple instruction on what port or pins are available inside of the torch that I can connect to?
    Also let me know if this sounds super crazy. Or if I am way off base.
    Jan 2008
    2247
    There is no auxiliary power in a Powermax45. I suggest you follow the wiring suggested provided by Proma THC.
    Jim Colt Hypertherm
    Jun 2009
    251
    Re: Proma THC & Hypertherm Powermax 45, faults in test mode. Bad power supply?
    You are supposed to use an external power supply for Proma THC, and i would venture to say that your input pins are not set corectly.
    Also, Mach5 ?????!!!!!!!! I am not aware that ir exists even in beta.
    Do some pictures of your wiring and your pin setup in mach3, it will work, don't worry.
  1. Proma THC works in test mode only
    By Chrome Cowboy in forum Mach Plasma / Laser
    Last Post: 08-11-2014, 01:28 PM
  2. Hypertherm M65m mini machine torch on Powermax 45 power supply
    By tmbg in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-19-2014, 09:56 PM
  3. How to test a strange power supply?
    By AlmostHandy in forum CNC Machine Related Electronics
    Last Post: 04-19-2009, 02:57 AM
  4. Switch Mode Rectifier as power supply
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 04-30-2006, 04:17 AM
  5. power supply test
    By dlenox in forum DIY CNC Router Table Machines
    Last Post: 04-28-2004, 02:06 AM
