Can the profile tool path feature be made to project onto a contoured surface like the v-carve feature?
For some reason the v-carve feature has some problems projecting single line type fonts, or more likely it's just operator error:tired:.
Yes. Just check the "Project Toolpath onto 3D Model" checkbox at the bottom of the Profile Toolpath Dialog.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
After you create the text, you need to convert it to curves, then use the profile toolpath on the converted vectors.
Gerry
Gerry
he probably try to use the vcarving on single vectors..
open vector error comes when you try to call an operation what require closed vectors..
pocketing, vcarving... and I believe sometime the vector Booleans also generate it..
