585,733 active members*
5,116 visitors online*
Results 1 to 6 of 6
    Sep 2006
    29
    Problem with laser machine
    Hi
    I have a redsail 50w laser machine that has stopped working , basically we had a power cut and the main fuse box tripped out, Everything else turned back on ok but the laser machine didn't .
    I have bought a new power supply today and changed it over but it still doesn't work,
    any ideas what else it could be?
    thanks chris
    Jun 2014
    611
    Re: Problem with laser machine
    Hello chris, do you have a water chiller to protect the machine? as you said you had a power cut, so I think you should lower the power or you can choose a larger power laser tube.
    Feb 2012
    387
    Hi Chris,
    here is some of our problem test video, hope can help you
    GWEIKE LASER - YouTube
    YouTube
    Quote Originally Posted by cdfracing View Post
    Hi
    thanks chris
    Lucy Lee G.WEIKE LASER
    [email protected]
    Sep 2006
    29
    Hello
    thanks for the video, but there is no power to the machine at all,. it's like it doesn't have a power supply fitted .
    we had a power cut that tripped out all our machines, which came back on except the laser machine
    Jan 2015
    9
    Have you bypassed the emergency Off switch.. Mine just all of a sudden broke, shutting it all down.
    Nov 2014
    284
    Did you plug something else into the wall plug to test it? Did you check the fuse locatated in the connector on the back of the machine where the power cable hooks to the machine?
  1. Artcut Problem for the Co2 Laser Machine
    By usmanulamin in forum Laser Control Software
    Last Post: 06-16-2014, 09:23 AM
  2. Problem with K40 Laser Machine
    By punkiegunner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-29-2013, 01:06 PM
  3. Shaking Problem On My Laser Machine
    By Karton in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-01-2013, 09:14 AM
  4. The problem of laser machine
    By mause in forum Stepper Motors / Drives
    Last Post: 03-23-2013, 03:16 PM
  5. Optiray Laser marking 150W machine problem
    By mecanicu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2012, 07:10 PM
