Hi my name is Mike and I have a cnc router ready to go however I need to have the g-code created for me and it should be very simple. I am willing to pay a set or hourly rate and if interested please let me know and we can talk.
Printable View
It's not that hard to create your own G-code, but it is difficult to create it for someone else. Each project has its own set of parameters, such as a certain material, a particular cutter, the quirks of your own special machine, the placement of your clamps and fixtures, the way you want the toolmarks to run, etc. that make being able to make changes on the spot essential. It's harder to explain all these things to someone than to just implement them in a CAM program. It's not really that hard to do. I'd suggest starting with a demo copy of DeskProto, which will work for free for a month, and beginning with some relatively simple projects, working your way up to more complex ones. Spending your time this way will be more productive than spending your money trying to get someone else to do it for you.
Andrew Werby
ComputerSculpture.com ? Home Page for Discount Hardware & Software
I can create for you g-code
You can draw and create Gcode or import DXF and HPGL files to create Gcode files with the Demo Version of SuperCamXp.
This is a link to the demo download.
SuperCamXp Demonstation Download
This is a link to a video on how to create the G code files from a simple drawing.
Super Tech's SuperCamXp Menus Links
Or you can use SuperCamXp with the ArmPod and there is no need for Gcode files because the machine will work directly form the drawings.
Hope that helps..
Dennis Bohlke
Super Tech & Associates Main Web Home Page
The links appears "This page cannot be displayed". If you give me a sample of g-code machine reads, the drawing you wish as DXF or CAD model, the list of tools in use and the type of control I can generate the g-code for your machine.
This is my e-mail
[email protected]
Best regards
