WOOD CNC ROUTER structure
Wood cnc router machine MT-C25B mainly used for 3d works. Like wood furniture, wood door, wood cabinet, pvc board, acrylic sheets etc. This machine can Engrave and cut on hard wood, MDF, Aluminum and plastic composite panel,Acrylic sheet, ABS double color sheet, PVC foam sheet, wooden sheet,PCB Aluminum sheet etc.
Wood cnc router machine MT-C25B equipment:
(1) 1300X2500mm work size, stepper motor (2) 4.5KW water cooling spindle
(3) DSP hand controller( easy to learn and operate) (4)Rack gear transmission, Z ball screw
(5) Taiwan imported square orbit, oiling systerm (6) 6 zones vacuum table and T-slot
(7) Two bags dust collector and 5.5KW vacuum pump (8) Ucancam V9 software
