CNC Vertical Double-Surface Grinding Machine
The products are mainly used in several fields including air condition compressor, bearing, gear, auto parts, hydraulic parts and other industries, besides, it can be used to grind some parts with difficult-to-cut materials.
Rough and finish grinding for two parallel surfaces can be finished at the same time and the outer surface of parts can be any shape. The grinding machine is suitable for processing parts with high precision demands because of its excellent performance.
Stability Accuracy
The feed tables are guided by rectangular slide rails adhered with soft belts, which can achieve high load-bearing capacity and good vibration resistance;
The feed tables are driven by worm gear and ball screw transmission pairs, so that the feed process is more stable and accurate;
This machine is controlled by stable program supported by advanced system in order to reduce the failure rate and stabilize the grinding process;
The positioning and repeat positioning accuracy of each table can be ensured through the optimized pitch compensation technology and the repeat positioning accuracy is less than 1 μ m.
High efficiency
Non-grinding time is largely shortened, equipped with double-position worktable and automatic loading and unloading system(optional), as a result, the production efficiency is largely improved with the processing time between 10 to15 seconds.
High reliability
Automatic dimension compensation
Dimensions can be self-corrected by adjusting feed table position automatically. The adjusting program is based on change rule and the compensation value can be regulated.
Operation grade setting
Key parameters are hard to be regulated by setting up different operation grades in order to avoid fault and damage caused by misoperation.
Automatic dressing
The performance of grinding wheel can be ensured by automatic dressing based on program in order to ensure the quality of ground workpiece.
