I have bought an old Hurco KM-3P mill off GovDeals and looking for some way for it to talk to a laptop so I can enter G-code into it. The parts I'm going to make are very simple, all I need is some way to type in the commands,
Printable View
I forget if it has a serial port if so look up how to make the cable for the machine and grab some dnc software . you can also make a text file with your code and save it as .hnc then save to a floppy disk .
there is a ton of info out and the layout of the menu system has not changed much over the years . I have run one of them and have run the winmax controllers .
tony
What you may need is a Hurco Manual called:
Conventional NC Executive for Hurco Ultimax Control
There will be 3 connections on the back of your machine.
They are military style and you need to make a cable from military to serial
in order to talk to the PC.. I don't know much about PC's , and the one I use to use was a Win 95 PC, so it had a serial port
My cable had only 3 wires for serial communication
The top military port ( #1 )is a output port only
The next lower port (#2) is for output and input ( ! )
the lower port is for forth axis communication
My baud rate was 9600 and the handshake was 7 data bits,one stop bit and even parity
It is in ASCII Format
the NC file first character must be a " %" sign and the last character must be a "E" to close the file
my notes say I talked to Steve Artz at Hurco and he sent me the info
For the cable I have:
Hurco port 2 to a 9 pin PC plug
D9 pin 2 TXD transmit data to > PC pin 2 RXD
D9 pin 6 RXD, receive data < from PC pin 3 TXD
D9 pin 7 DTR data terminal ready > PC pin 4 DTR
D9 3 Signal ground---------------------PC 5 connect to shield at machine only !
I also have this
#3 to #2
#2 to #3
#7 to #8
#8 to #7
#5 for ground shield
This was 10 years ago and i don't recall which cable was used as I had to play with it
I know that Predator makes a cable(Grizzly) for the Hurco DNC work
Predator Hardware - Wired or wireless rugged MDC, DNC or CNC Networking Hubs, RS232 hardware or Predator Grizzly cables
Rich
You may have help here at the Hurco website
FAQ - HOW TO HOOK UP A RS 232 CONNECTION TO A HURCO WITH ULTIMAX CONTROL. ALSO HYPER TERMINAL SETUP INFORMATION
Rich
That pin configuration sounds right .I made a cable for work you can get db-9 ends at RadioShack before they go under ! If you make your own I would recommend soidering the wires to the pins !
Tony
Thanks to everyone, my biggest problem is that I am very new to this kind of stuff. The owners manual say's it is was made in1986, but does not say if it was a ULTIMAX, where can I find that information
Grab a manual from hurco the programming concept is the same over the years and will help
Tony
I have found out that it might be a BX control, does that matter?
