I NEED A THREAD MILL PROGRAM TO THREAD A 1/4 -18 FEMALE THREAD IN 316 SST. YES I KNOW I CAN SINGLE POINT BUT TOOL LIFE IS TERRIBLE I WANT TO USE MY Z AXIS LIVE TOOLING AND THE C-AXIS.
THANKS
BAD DOG
DAEWOO 240 MSB
Printable View
THANKS
BAD DOG
DAEWOO 240 MSB
I am assuming that your Thread Milling on the Face of a Part.
Is this a Fanuc Control, if so which series?
Also i am assuming that you want to use a Hob End Mill, What Diameter??
YES---FEMALE THREAD, FROM FACE,,,,, .292 CUTTER DIAM.,,,,, FANUC 18 i CONTROL
WE MACHINE A LOT OF 316 SST,,,, WE USUALLY 2ND OP THESE IN THE VMC BUT I NEED TO HAVE THEM COME OFF THE MACHINE COMPLETE.
THANKS,
BAD DOG
Do you have a Full Y Axis instead of using the C Axis??
If so, how much travel do you have?
NO Y-AXIS THAT IS WHY I WANT TO TRY USING C AND LIVE Z AXIS TOOLING
BAD DOG
Does your C-Axis Program in Degrees or an Inverted Scale??
POLAR,,,,,,,
Crap!!!
LOL, post this in the Mastercam area, maybe someone there can help.
Sorry.
HEY,,,,,
THANKS ANYWAYS. I JUST MIGHT TRY IT LONGHAND.
BAD DOG
I run this on my Puma 2500 SY
1/4-18 PITCH N.P.T. THREAD MILL USING C AXIS AND LIVE TOOLING
N30T1111(27/64" DRILL)
M24
G99
G54.1P1
G97S1500M3
G0X0.Z1.M8
Z.1
G1Z-.945F.004
G0Z1.M9
M5
M1
N40T0909(1/4 N.P.T. REAMER)
M24
G99
G54.1P1
G97S1000M3
G0X0Z1.M8
Z.1
G1Z-.9F.012
G0Z5.M9
M1
N50T0707(3/4 45 DEG. CHAMFER)
M24
G99
G54.1P1
G97S3000M3
G0X0Y0Z1.M8
Z0
G1Z-.185F.006
G0Z5.M9
M1
N60T0808(18 PITCH N.P.T. THREAD MILL)
M24
G54.1P1
S2315M33
G0X0Z.1C0M8
G98
G1Z-.6F50.
X.168Z-.5725H180.F7000.
Z-.5169H360.
X0Z-.4891H180.
G0Z5.M9
G99
I know this is an old thread but have you figured it out? I just had success programming a thread mill but using Cartesian to polar coordinate transformation on my fanuc control wouldn't work.use the y axis trust me. That way you can use the radius offset in your offset page which controls the y axis to control the dia like g41 cutter comp on a mill works.i can post an example if u want.im just replying to put the info out here in case you come across this again or it helps someone else.Best of luck
