Republic Lagun KMC-250 eating drive belt belts
my republic lagun is eating belts.
just on 3rd one
1 1/2 hours of running continuous cutting a die and have a small bubble on outer edge of belt.
I am using 37 x 10 x 900 LI belts. mm
is this the correct belt?
today after running, I put my finger through one of the side port holes to check the temp and felt that the belt has quite a bit if slack in it when not running.
is this usual?
variable speed through a pulley drive system, operated manually.
any comments or ?????????? would be gratefully appreciated.
Thank you for your time.
Your efforts are appreciated.
Charles
