150watt Metal & non-metal laser cutter for Acrylic,MDF,sss,Carbon steel.
NO. |
parameters |
1 |
Working area |
1300mm*2500mm |
2 |
X axis |
1300mm |
3 |
Y axis |
2500mm |
4 |
Z axis |
40mm |
5 |
X.Yposioning accuracy |
≤±0.05mm |
6 |
X Y resettin gposion accuracy |
≤±0.01mm |
7 |
X Y max posionting speed |
20 m/min |
8 |
Laser power |
150W |
9 |
Cooling system |
CW5200 |
10 |
Cutting object precision |
±0.05mm/1000mm(steel) |
11 |
Cutting material thickness |
steel<1.5MM
stainless steel<1.5MM
acrylic<30MM |
12 |
Whole machine size |
3600*1850*1300 |
13 |
Controller |
Leetro |
14 |
Weight |
1000Kg |
15 |
Power |
4KW |
16 |
Voltage |
220V |
17 |
Herz |
50Hz |
The advantages of LC1325M:
LC1325M is a mixing cutting machine, specialized in cutting stainless steel, carbon steel, MDF and arcylic.
High efficiency: The cutting speed of 1mm stainless steel is 1800mm/min.
20mm arcylic with perfect cutting quality.
LC1325M machine is matched with the Panasonic Servo System and high precision.
ball-screw system to ensure the high precision, running stable and long-operation.
Low running cost about 5KVA/hour.
Looking for wholesales sincerely.
Skype: Angela Jinan
Contact: Ms. Angela
MSN: [email protected]
Samples:
http://www.alibaba.com/product-detai...010677842.html
